Hard water drip
The OP has stated that he doesn't have access to an outlet. So, after washing the car and drying it, slide a paper towel under the mirror its self and it will pull any water that is in there.
The problem with the mirrors, is they hold a lot of water. If you don't have access to an outlet, I would order a set of the mirror covers so you don't continue to have this problem. until you get the covers, you can buy a 3 pack set of the compressed air in the can at Office Depot or any place like that. Use them to blow out the excess water. After that take some paper towels and slide them up in and around the mirrors to soak up the remaining water.
Before I spray any water on my car, I wrap the door mirrors with saran wrap. After I wash the car, I remove the plastic wrap, and clean the mirriors without spraying any water on them.
Got rid of the dripping water for me.
I have hardwater, too. I take it to a car wash, spray wash it, drive it home and let the wind (a short spurt at about 80 mph) blow it off. (Most car washs around here really soften their water.) Then, when I get home, I towel dry the rest. The damp towel takes the water spots off. Any bugs get removed with McGuirers cleaner wax. I keep enough McGuirer's Carnauba on it to keep the water spots off and keep it from being scratched. It works for me.
There are a few ways to prevent the water spots, and most have been mentioned. Your questions is how to get rid of them now that they are there. I would think any good car polish and foam applicator would clear it up. Depending on the polish, it may remove any wax you have, so you will need to wax that area again. Vinegar and water will also remove wax.
You learn over time which places to be carefull with direct spray...side mirrors and tail lights...shoot those quickly and at an angle where you don't just load them up with water...they will drip for hours if you don't learn the trick..
