Check engine light
Old 12-03-2012, 11:43 PM
609thomasm
609thomasm's Avatar
Default Check engine light
The CEL came on the other day. Is there a way to bring up code without a reader? 2009 coupe with just over 18,000 miles. Thanks
Old 12-04-2012, 12:11 AM
cclive
cclive's Avatar
Nope, gotta have a scanner. If you want a very simple one...this is one that I got to keep in the car.
http://www.amazon.com/gp/product/B00...ls_o05_s00_i00
Old 12-04-2012, 11:48 AM
Landru
Landru's Avatar
Received 1,047 Likes on 821 Posts
If you don't want to lay out the coin for your own scanner?
Most every auto parts store, like Auto Zone etc, will check for codes using their scanner as a service to the customer no charge.
Old 12-04-2012, 01:31 PM
NevadaVette
NevadaVette's Avatar
The car also throws bad codes. Try disconnecting the battery and see if that clears it.
To Check engine light
Quick Reply: Check engine light
