Annoying clicking noise?
Old 12-01-2012, 02:18 PM
AV8TOR536
AV8TOR536's Avatar
Default Annoying clicking noise?
It just started to do it,I have a clicking noise,not all the time but at random times...the sound seems to be coming from the air vents on top of the radio (6 cd changer).
I turn the radio off and it still does it,fiddle with the heater buttons..still does it...mmmmmmmmmmmmm
What could it be?
I forgot to mention that the car is a 2005 C6.
Old 12-01-2012, 02:31 PM
aquavettes
aquavettes's Avatar
The cd changer cycling?
Old 12-03-2012, 08:51 AM
Don Nolan
Don Nolan's Avatar
Air conditioner? Check it out.
Old 12-03-2012, 09:11 AM
RainMan12
RainMan12's Avatar
I believe there is a small cooling fan that is part of the ignition switch that sometimes will rub and make strange noises.
Old 12-03-2012, 05:53 PM
CO Lightfoot
CO Lightfoot's Avatar
Originally Posted by AV8TOR536
...the sound seems to be coming from the air vents on top of the radio...
If it's actually coming from the passenger footwell, might be the normal clicking sound of the brake relay.
Does it only happen when you press the brake pedal?
Anyway, if you've got a 4-prong relay, it's easy to replace with the quieter new 5-prong relay:
http://forums.corvetteforum.com/c6-c...nd-normal.html
Originally Posted by lastcowboy
there should be 5 prongs on the relay gm only put 4 , i put the new one inwith 5 it stoped , this is the new one
Old 12-03-2012, 08:44 PM
tlr3715
tlr3715's Avatar
Brake relay click was not an issue in 2005.
To Annoying clicking noise?
Quick Reply: Annoying clicking noise?
