Why not just wrap it?
So much discussion on heat inside the car and some rather extensive work to reduce the inside cabin heat....
Seems easiest/simpler to me, just wrap the bulk of the exposed exhaust (not the cats or mufflers). I'd think that would work and actually take much less time than gutting the interior and laying heat shield all about. Hit it at the source.
What do you think. Why not just wrap it in a 2K degree blanket?
Seems easiest/simpler to me, just wrap the bulk of the exposed exhaust (not the cats or mufflers). I'd think that would work and actually take much less time than gutting the interior and laying heat shield all about. Hit it as the source.
CF Senior Member
My impression is more people use interior insulation for noise abatement rather than for heat. I think adding a thermal 'blanket' to a beefier tunnel plates makes more sense for heat mitigation that trying to wrap the entire length of the exhaust pipes. Personally, I've never felt the interior cabin heat (or noise) was excessive or bothersome.
I haven't driven mine thru AZ during July yet but so far what gets hot are the OEM cup holders and the console's interior. I think the under tunnel should be much better insulated to block the exhaust heat from permeating the underside of the console. As 'the' uber sports touring car, it should have no hot spots anywhere in the cabin. A race version can be stripped of heavy insulation but not my road car!
Covering the interior is more for noise. The blocked heat is just an added benefit. Besides, wrapping the entire exhaust would probably be a lot more expensive.
Received 2,051 Likes
St. Jude Donor '13
Hot Console: put in the graham crackers, Hersey Bar, and marshmallows. S'mores at your destination.
This car has more features than most people know...
I've had the same thought as the OP. Ever notice how a sheet of aluminum foil prevents the Thanksgiving turkey from over-browning in the oven? That's because it reflects oven heat very efficiently. Have you seen the insulating inserts they make for your C6 cup holders and center console floors? The reason they work is due to the aluminum foil, not the super-thin covering on the foil. Even under the hood of most cars you will find aluminum foil used to reflect manifold heat away from spark plug wiring, etc. The only thing you wouldn't want to use around your exhaust is aluminum foil bonded to another material like foam rubber or paper of any kind; that might work on hot water pipes, but would probably catch fire around exhaust pipes. However, their are wraps out their for exhaust manifolds and pipes that I'm sure would work very well. Why doesn't Chevy put it on the exhaust underneath the passenger compartment? Hey, they eliminated the center console lock and under hood lamps to save what, a couple of dollars? This is a Chevrolet folks, that is how they think.
wrap it
My experience with the header wrap is it will cook your headers within a year. They become brittle and crack. I had to replace at least every other year. That being on a daily driver.
Ceramic coating makes a huge difference in the engine compartment. I've been able to touch the headers within 10-15 minutes of shutdown. I've even coated my turbos and eliminated the heat sheild.
Jerry
Jerry
I have LG long tube headers and called them directly and they said do not wrap them. I believe they will just get too hot. They are stainless steel, so I don't think they would corrode. It may be okay to wrap them lightly downstream of the cats (tunnel area) , but they did not commit to that being ok.
What does "This is a Chevrolet folks,that is how they think." mean? It is not a simple task to design and manufacture automobiles. Take a look under your Corvette, you should very quickly see why you can't run the exhaust under the passenger compartment. GM has done a great job with the C6.
Gee, it is not a simple task to design and manufacture automobiles? I would have never known that if I hadn't personally spent over four decades in this industry. GM did run the exhaust system under the passenger compartment of every C6 without adequate heat insulation, thats why the passenger compartment, cup holders and center consoles have well documented heat problems. Anyhow, let us just say you and I may disagree a bit, but I still respect your opinion, and especially your right to express it. Peace.
