LS2 / LS3 Fuel Rail Cover Question
Old 11-06-2012, 02:30 PM
Spark 2
Spark 2's Avatar
St. Jude Donor '07-'08-'09
Default LS2 / LS3 Fuel Rail Cover Question
Has anyone removed the foam insulation that is mounted under the
FRC?
What if any were the results?
Cooler running?
More engine noise?
What are your thoughts and or opinions?
Old 11-06-2012, 02:52 PM
bud miller
bud miller's Avatar
FRC?
Cooler running?
More engine noise?
yes..no more noise, that i could tell...ya think its gotta run cooler..that foam must absorbe the heat.its like putting a foam blanket over the engine..check my post on pic's ls7 exhaust on ls3 for some pics...if ya want
Old 11-25-2012, 10:28 AM
Spark 2
Spark 2's Avatar
To the top please!
Any other experiences?
Thanks!
Old 11-29-2012, 08:32 PM
Bedouin
Bedouin's Avatar
I removed both the FRC's on my '12 LS3 & the foam-insulated intake manifold cover too.
The FRC's come off easily, & the intake cover took @ 30 mins because I wanted to retorque the 4 bolts that I loosened correctly. If you loosen/retorque all of the intake manifold bolts, there's a specific sequence to follow.
I really didn't notice much, if any, extra noise, I just didn't like the plastic things & wanted the engine to get more air circulation as well.
To LS2 / LS3 Fuel Rail Cover Question
Quick Reply: LS2 / LS3 Fuel Rail Cover Question
