question about Paddle shift
Old 11-30-2012, 07:55 AM
bucwheat
bucwheat's Avatar
Default question about Paddle shift
Hey guys,new GS owner here,the manual says that when paddle shifting with trans in S mode ,the gear you are in will appear on the DIC,mine only shows the odometer reading how do you get the gear to show?
Old 11-30-2012, 08:07 AM
Thomasmoto
Thomasmoto's Avatar
Received 1,505 Likes on 1,027 Posts
Do you have HUD?
Old 11-30-2012, 10:28 AM
Vette_DD
Support Corvetteforum!
Vette_DD's Avatar
Received 1,276 Likes on 935 Posts
If your car has the HUD, it will display on that.
Old 11-30-2012, 11:17 AM
bucwheat
bucwheat's Avatar
Yea ,it has HUD I will look next time,I though t I read that it would display on the DIC. Thanks,Bobby
Old 11-30-2012, 11:59 AM
Vette_DD
Vette_DD's Avatar
But only if you're using the paddles. If you're letting it do the shifting, even in "S" mode, what gear you're in will not show up on the HUD or the DIC.
Old 11-30-2012, 12:03 PM
BWF07
BWF07's Avatar
St. Jude Donor '11
Oldtimer
Everything said is correct. However, when you put it in the sports mode, you must select the paddles by pressing one. It will then show what gear you are in in the HUD. If you do it at a stop, it will show a 1 in the HUD in a little box. I do think that if you have the Nav running it will then be in the DIC, at least when the Nav is showing on the HUD.
Old 11-30-2012, 12:25 PM
Thomasmoto
Thomasmoto's Avatar
Yep, that's it.
Old 11-30-2012, 02:33 PM
bucwheat
bucwheat's Avatar
Just saw the other thread about this didn't mean to start another,sorry.
To question about Paddle shift
Quick Reply: question about Paddle shift
