Corvette Forum
Go Back   Corvette Forum > C6 Corvette, 2005 - 2013 > C6 Corvette General Discussion
Register Forgot Password?
Register Vendors Buy a Vette Albums Search Today's Posts Mark Forums Read FAQ TSB & RecallsGarage
Search
General C6 Corvette Discussion not covered in Tech Sponsored by
PFYC
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 11-23-2012, 07:07 AM   #1
NoXcape
CF Senior Member
NoXcape's Avatar
Default FUSTRATED. Need help finging 3rd gear
For some reason under full acceleration I can not get my car into 3rd gear. It feels like i'm hitting a bump stop or inbetween gears. Under normal driving and shifting it is fine and smooth . I've tried to not have the death grip and even the palm method but nothing works. Car is only 1 year old..6k miles,,,clutch fluid changed...and not driven hard at all.. Would a short shifter solve this problem? I assume that taking the traction control off has nothing to do with this but fig i'd throw that out there as well ( I forget to take it off). I would love to take my car to the 1/4 mile track but fig no point until i get this fig out...
Any help appreciated.. I did watch Rangers vid on shifting as well...
NoXcape is offline   Reply With Quote
Old 11-23-2012, 07:10 AM   #2
mksz51
CF Senior Member
mksz51's Avatar
Could be the vague factory shifter. I would (and did) change the factory shifter to an MGW. BEST mod I've done to my car. You'll be amazed when you see the difference in build quality from the factory shifter to the MGW and then impressed further when you use it.
mksz51 is offline   Reply With Quote
Old 11-23-2012, 07:33 AM   #3
heli-vette
CF Senior Member
heli-vette's Avatar
+ 1 on the MGW shifter and if you are close to an oil change on the M6 transmission ( mobile 1 ATF ) ...that helps to lighten and smooth out the shifting forces .
heli-vette is offline   Reply With Quote
Old 11-23-2012, 07:40 AM   #4
Mad*Max
CF Senior Member
Mad*Max's Avatar
Mad*Max is offline   Reply With Quote
Old 11-23-2012, 07:46 AM   #5
Dave S
CF Senior Member
Support Corvetteforum!
Dave S's Avatar
Are you aware of the "skip shift" feature in 6sp Vettes (and other GM 6sp models)? This feature forces shifting to a higher gear under certain load conditions.....all in the name of meeting Fed mpg mandates (or more accurately....avoiding the "gas guzzler" tax). Most of us have installed so-called "skip shift eliminators". Available from most of the Forum parts vendors for $20 or less....there is also a DIY resistor install. Do a search for "skip shift eliminator".
Dave S is offline   Reply With Quote
Old 11-23-2012, 07:50 AM   #6
Double D Mods
Supporting Vendor
St. Jude Donor '12-'13
Double D Mods's Avatar
Double D Mpds
Quote:
one of these is what he is talking about
http://shop.doubledmods.com/searchqu...?keywords=cags
Double D Mods is online now   Reply With Quote
Old 11-23-2012, 07:59 AM   #7
01VETTECOP
CF Senior Member
01VETTECOP's Avatar
Have you ever checked your muffler bearings ???
01VETTECOP is offline   Reply With Quote
Old 11-23-2012, 08:25 AM   #8
shawn672
CF Senior Member
shawn672's Avatar
If he's at WOT and shifting into 3rd, we can safely assume he WAS in 2nd, which means CAGS has nothing to do with it since it will only activate when you're in 1st gear.
The OP is hitting the bumper between 1st and 3rd it sounds and it may be because the shifter floats back to the center on it's own (right below 3rd and 4th). OP, it sounds like you're shifting from 2nd to 3rd pretty quickly and may be pushing the shifter almost straight up out of 2nd, try giving it more angle so it pops far enough to the center (also the shifter will tend to want to go to that location on it's own).
This is much easier showing you in person, perhaps there you know someone local who also owns a vette who can show you?
shawn672 is offline   Reply With Quote
Old 11-23-2012, 09:14 AM   #9
dvilin
CF Senior Member
dvilin's Avatar
I had the same problem but it was me. Once I began using the so called palm method and pushed the shifter almost straight up into 3rd it has been a non issue.
I have found under WOT you do tend to want to slam it into gear. If you are convinced you can not hit 3rd gear under WOT, and there is nothing wrong with the car, I would go with the MGW shifter.
dvilin is offline   Reply With Quote
Old 11-23-2012, 09:27 AM   #10
Flh Den
CF Senior Member
Flh Den's Avatar
Do you lift when shifting into 3rd or power shift? There must be quite a few members who drag their C6's who could give you a few tips on shifting. I personally have an MGW shifter but not being on the strip I always lift and shift a bit slower and never have any problem, but then again I rarely shift at redline.
Flh Den is offline   Reply With Quote
Old 11-23-2012, 09:29 AM   #11
Flh Den
CF Senior Member
Flh Den's Avatar
Old 11-23-2012, 09:31 AM   #12
barduch
CF Senior Member
barduch's Avatar
I just posted on an MGW thread but I'll report from the "office of redundancy office". With the MGW, the second to third shift will bring tears to your eyes. It is seamless whether normal or very aggressive power levels are being utilized.
barduch is offline   Reply With Quote
Old 11-23-2012, 01:13 PM   #13
brooklync5
CF Senior Member
brooklync5's Avatar
Monster1234
Send a message via AIM to brooklync5
Mgw shifter is the cure for your 3rd gear woes.
brooklync5 is offline   Reply With Quote
Old 11-23-2012, 01:32 PM   #14
NoXcape
CF Senior Member
NoXcape's Avatar
I guess im just going to have to try and slow down just a little bit on that shift..I will get the MGW and see if that helps. I wish i could tell if i have to angel a tad more to the left or a tad to the right lol to get it in there right...
Old 11-23-2012, 01:36 PM   #15
mksz51
CF Senior Member
mksz51's Avatar
Try this - push it forward out of second, pause a split second to allow it to center in the gate, and then push forward again into third. Remember - the "default" gate is 3-4. This works VERY well with the MGW - it is so precise you'll instantly get it.
Old 11-23-2012, 01:40 PM   #16
NoXcape
CF Senior Member
NoXcape's Avatar
Thx Mks..i ll try that...what do you mean be Default 3-4?
Old 11-23-2012, 01:52 PM   #17
JLMounce
CF Senior Member
JLMounce's Avatar
@jlmounce
You're trying to "guide" the shifter when it doesn't need to. It guides itself. Thus you're hitting the gate and not entering in the gear.
To fix this, stop holding on to the shifter. Instead, for shifts towards your body, cup the top of the shift **** with your hand and pull towards you. For shifts away from your body, push the shift *** with the palm of your hand. This will stop and side-to-side motion that grabbing the shifter causes. It will naturally flow in to gear from there. Even during speed shifting.
JLMounce is offline   Reply With Quote
Old 11-23-2012, 01:56 PM   #18
mksz51
CF Senior Member
mksz51's Avatar
if you put the vehicle in neutral and then pushed the shifter directly forward or pull it directly back it will go into 3rd or 4th gear, respectively. Think of 3 parallel gates - pull it left and you're in 1-2. Let it "center" naturally and you're in 3-4. Push it right and you're in 5-6.
Old 11-23-2012, 02:04 PM   #19
shawn672
CF Senior Member
shawn672's Avatar
This is a great description of what I was trying to say.
Old 11-23-2012, 03:35 PM   #20
Jimmy W1
CF Senior Member
Jimmy W1's Avatar
Dealer time!!
Jimmy W1 is offline   Reply With Quote
Reload this Page FUSTRATED. Need help finging 3rd gear
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.2
Emails & Password Backup
