Pilot Super Sport air pressure ?
What's the recommended air pressure for my 2010 GS , with newly installed Michelin Super Sport non-RunFlats ? ( stock sizes )
Discount Tire installed them at 26 psi , but that seems low to me ...
Where do you guys keeps them ? ..... 30 psi like my old Goodyears ?
Thanks !
Thanks !
Received 3,289 Likes
St. Jude Donor '12-'13-'14-'15-'16-'17
Whatever the sticker on the driver's door jamb says.
I run mine at 32 cold, which is what the sticker on mine says.
I have the exact same tires. My door jam on my 13 GS says 30psi but that is based on OEM tires. Non run flats don't have as stiff sidewalls. I run mine at 32psi and with over 5k miles on them the tread wear is even across the tread.
In Utah the tire pressure monitor likes to read about 10% low anyways so it usually reads 27psi. Colder temperatures would cause the warning light to go off.
I did run them at 30psi in the beginning and it felt too soft.
That too , is really good information ... Thank You !
Maybe I'll try em at 32psi as well ...
Last edited by New World Matt; 05-04-2013 at 11:51 PM. Reason: Additional thoughts
Thanks !
Thanks !
Thanks for all the input guys !
I'm going for a cruise today ( it's BEAUTIFUL in Chicagoland !! ) and I'll bump up the pressures in my Super Sports to 32psi , and see how they feel !
This forum rules ! .... Matt
