Can a Z06 FOB be used with a C6?
Can a 2007 Z06 FOB be used with a C6? They look totally different. My remotes have either a #1 or #2 on the backs so each fob can have driver settings associated with each fob. The Z06 Fob doesn't have any identifying number.
Moderator
Received 3,589 Likes
Yes. There is no special fob for the Z06 (or ZR1 or 427 )
All Corvette fobs from 2005 to the present are interchangeable. Instructions to program:
http://forums.corvetteforum.com/c6-c...tructions.html
FYI...the FOB is on the 2008 up C6's does have the "1" or "2" stamped on the end of the FOB.
Received 2,053 Likes
St. Jude Donor '13
We had a 2006 with the old style fob, traded for a 2009 with the new style.
The new style fob is a major step backwards-
Bigger
Heavier
Case seems easier to damage when changing battery.
If you lock your fob in the car, you've also locked in your key.
Hard to remove key from fob.
Objects in your pocket are much more likely to press the fob buttons, like the panic alarm.
