Problem with key fob
Hey, I have a 2005, been having problems with the key fob not unlocking the driver door, it acts like it will, but won't unlock. I can unlock with the same key fob the passenger side, reach over and use the emergency door opener, and the key fob will allow car to start. Has anyone experienced this problem. Both key fobs are new, and were working fine until this weekend. Thanks for any and all help. Patti
Might be time to clean the outside door switch.
Very easy to remove, 2 screws, and then open it up and blow the dust/dirt out.
Pretty common problem. Try a Forum Search for this well documented DIY fix.
