Alternator Capacity?
Received 2,059 Likes
St. Jude Donor '13
We don't get hurricanes in Illinois, but every year a windstorm typically causes us to lose power for 1-3 days.
Gasoline generators are expensive and people seem to have a lot of problems with them.
Consumer Reports recently tested and recommended a couple of power inverters that can be run off your car battery, while running the engine so the alternator keeps the battery charged. There are many other models available.
I wouldn't want to buy an inverter that would overload/ruin the alternator in our C6 or our two other cars (2005 and 2011 Toyota Camry), so I need to know what the C6 (2009 coupe) alternator is rated for, and if it's ok to run it for hours on end at the full rated load.
Suggestions?
Thanks!
Suggestions?
Thanks!
To answer the question asked, I believe the alternator in the C6 is rated at 100 amps. I would not suggest using the car with an inverter to supply 110 volt current though. I believe that generators are actually fairly inexpensive. $700 can get you a good one that will supply far more power more reliably than a Corvette.
At 100 amps, the alternator will only make about 1200 watts at max rated output. Some of this must run the car's electrical system, some will be lost when converting to A/C in the inverter. For $700, you can have a generator that will supply you net net 3,000 to 4,000 watts of 110 volt A/C.
Another thing to remember is that the alternator is not putting out maximum at idle, the RPM's need to be up to a certain point to get the max. Do you want to run the car that way for hours at a time?
For the power you would be getting out of the car, you would be better off with a $300 generator.
St. Jude Donor '13
Our neighbors with gasoline generators seem to have endless problems with them-
Must store extra gasoline
Must drain the tank for indoor storage, or store outside
Must start it periodically to avoid engine problems
Numerous misc problems when they actually try to use the generator
We don't need big wattage-
Big woodstove keeps the house warm
Gas grill for cooking
Gravity drain septic system
Big hot water heater for emergency water supply, and pond next door. Plus bottled water
We've been there and done that for 30 years here. But it would be nice to have a simple system that can run the refrigerator and freezer enough to keep food from spoiling. If that can be done with a no-maintenance inverter, that's my choice. We have 3 cars to connect to, so there will be enough gasoline and 2 "backup" cars (Corvette would be used last).
I don't believe that a car would put out enough power to run one refrigerator. Also, an inverter big enough to do that would be big and expensive and also require some sort of direct connection to the car's electrical system because a cigarette lighter plug is only good for about 20 amps max...which is only 240 watts. I would estimate that a refrigerator would require at least 1,000 watts at startup.
St. Jude Donor '13
Consumer Reports had a short report on a 900w and 1,500w inverter (June). Tested in their lab and apparently satisfactory, no adverse comments. Used at a staffer's house during a power outage, the smaller unit was able to power a refrigerator and sump pump at the same time.
The prices were $80 and $180. Size is "shoebox", not a problem to keep in the garage.
They did say you want to connect directly to the battery, not use the cig lighter plug.
The increase would not be significant anyway. 30 extra amps is only an extra 360 watts. To do anything meaningful with 110 volt devices, we need to be talking in thousands of watts, not hundreds. To properly utilize the power of the car, the engine should be connected to a generator that is similar in size to the engine itself.
St. Jude Donor '13
Let me see if I got this right. You are going to run a $12,000 engine to make something less that 1500 watts. Now I have spent a dozen years dry camping with generators and a 1000W inverter. The last 5 years with a pair of Honda EU2000s. (under $900 each delivered) They were and still are trouble free. They are quiet and easy on gas. I start mine every three months just to cycle a little fuel through the carbs. No need to drain the fuel ever. I do keep ten gallons of gas on hand to refuel my ATV, mowers, snow blowers etc. Later! Frank
If I were going to do this on a regular basis, or had only one car, that would be different. But running the inverter 1-3 days per year, split among three cars, for a few hours each day, seems pretty easy.
Was just wondering if this was available to Corvette.
When the Highway Patrol here used the Mustang 5.0 in the 80's to 93 as pursuit vehicles they used this 130 AMP alternator for all of that extra electrical equipment like lights and siren. They also added silicone hoses and extra pan / seat reinforcement.
Received 2,062 Likes
A fully loaded fridge and freezer is far more energy efficient than partially filled. So fill up any empty space with water, which when frozen or chilled will provide a heatsink during a power failure.
Since you have both a freezer and fridge, you can use the fridge freezer for ice storage.
If the power outage lasts more than a couple days, invite the neighbors over for dinner to use up some of the food and have them bring the generator too.
St. Jude Donor '13
That's basically what we've done, and we also buy extra ice if the power outage is very local.
Not many small generators in the neighborhood now, many folks have converted to those big honkin' units that run on natural gas and start/transfer automatically. I'm too cheap to spend $7k+ to get one, rather spend the money on the Corvette.
no carb problems with this set up
Received 8,958 Likes
The most effective way to run the house is to get yourself a residential generator Vs a portable generator. You can get a nice 7K Watt generator for about $2K that runs on either natural gas or propane and comes with an automatic transfer switch. It will power your critical items and some lighting and all you have to do to test it is throw the main circuit breaker once per month. If you have a propane tank you need to size it so you can run at least a week on the amount in the tank. I was just looking at one of these in the Northern Tool catalog that just popped into my email today. NG or LP engines don't make as much noise as a gasoline engine so that helps as well. Hooked up to a NG line you could have pretty much an endless supply of electricity as long as the utility's pumps keep pumping gas into the line. You would have spend a another couple of K to change the gas inlet to the house to handle the extra gas pressure required by the generator without blowing the lower pressure appliances in the house.
Bill
Bill
St. Jude Donor '13
But we could block it in with another car.
Or lock a chain around a wheel/suspension to make a "boot".
Suggestions?
Thanks!
Suggestions?
Thanks!
