Full boltons + cam
Full boltons + cam
Hello there..
time to mod the vette.. 2007 LS2 A6 ..
going to make it full boltons .. but im also considering adding a cam
Any suggestions? and what do I need to do .. whats the best cam u guys see .. im looking for a very good one..
thanks
thanks
If your going to a bigger cam. Then why do tge whole top end? Cam and lifters ,ported heads, intake,fuel injectors,CAI, headers, high flo cats.ported TB. and a good tune to make it all work. Or just bolt on a supercharger and tune it.
There's really no such thing as a "good cam." You need to determine what it is you're going to be doing with the car and select a cam profile that is optimized for that.
Just simply saying "x cam is a good one" will probably put you in a situation where your car doesn't perform how you wanted.
Some cams create lots of real peaky power that dulls throttle response. Others create lots of torque, while others fall in between that.
If you're seriously considering doing a cam, you need to contact an expert that deals with them. But before that you need to know what you're putting on the car and what it's intent is. Without that information, you might end up picking a cam that is completely wrong for your application.
Sure there's members here than can rattle off a list of cams for you that will pretty much all make some more power for you. But the question is how do you want the car to perform?
Do you care of driveability and mileage. Do you have an auto or a manual. If you have an auto, does it have the standard converter or aftermarket. Do you cruise the car or race it? If it's raced, are you drag racing, road racing auto crossing or doing land speed events?
Here's an example. I watched a good friend of mine purchase some top end goodies for his 5.0 Mustang GT years ago. He piece-milled this stuff together based on the deals he could get. So he ended up with some aluminum GT40 heads, a Trick Flow R upper and lower intake and a comp cams X series hydrolic roller camshaft. Then he sourced some off-brand 1.6 ratio roller rockers. He put about $5000.00 in to it all said and done.
What he ended up with was a car that made about 40 more hp at the wheels then it previously did. The caveat being that the extra power was so peaky and high up in the rev range that he actually made the car slower in 90% of the driving he did with it.
