Window won't roll up.
Old 10-29-2012, 04:53 PM
snoopdan
snoopdan's Avatar
Default Window won't roll up.
..and no, it doesn't seem to be a re-indexing issue and I haven't tried it either.
Basically, the retards at the shop that it was at let the battery run down, and the entire car lost power at one point. I needed to get a new battery anyway so I put one in. Window wouldn't roll up...but it would roll down (or try to roll down further until it stopped) Push on it to roll up and you hear some noise as if the motor was actuating then you hear a relay click...thats it.
Any thoughts before I pull the door panel?
Old 10-29-2012, 06:32 PM
5knives
5knives's Avatar
You have to reindex the windows. It's in the manual.
I "think" you put the car in ACC mode and hold the up position of both window buttons for 3 seconds. Check the manual it has the full procedure. Pretty easy. You don't have to remove the door panel.
Old 10-29-2012, 07:05 PM
C6ToGo
C6ToGo's Avatar
Received 1,116 Likes on 693 Posts
May be window regulator.
This TSB says funny acting power window may be the exterior door switch.
#08-08-64-001B: EI08034-Power Window/Regulator Concerns, Inoperative, Intermittent, Indexing, Continuous Up and Down (Diagnose Door Handle Switch, Replace if Necessary) - (May 30, 2008)
Old 10-29-2012, 08:52 PM
speedlink
speedlink's Avatar
It probably just needs to be re-indexed. Read the manual!
Old 10-29-2012, 09:09 PM
VET4LES
VET4LES's Avatar
I've replaced both of my window regulators in the last year or so. I had the same problem. First the passenger window and six months later the drivers.
Old 10-29-2012, 10:01 PM
Old Coot
Old Coot's Avatar
Make sure the door is closed when you try to roll it up. I had the same problem when my battery was down. After recharging the battery, I tried to close window with door open and it would nnot go all the way up. Closed the door and the window went all the way up. Then reindexed it.
To Window won't roll up.
Quick Reply: Window won't roll up.
