Need exhaust (upgrade) advice please
Fellow Corvette Drivers,
I drive a 2008 C6 LS3 Z51 - with the base standard exhaust system - which is rather whimpy sounding and does not do the car justice.
I have searched the Forum in vain trying to find advice about what type of exhaust system is the best dollar-for-dollar. I cannot find any threads, thus I am posting this one.
I am looking for an exhaust system that is slightly more “grunty” than the GM $1600 exhaust upgrade, but not as loud as the Billy Boat (Bullet I think it is called). I don’t want to rumble the buildings driving down the street, but if I am to spend money on an exhaust – I would like a bit more than the GM "upgrade" exhaust.
QUESTIONS:
1 - What is a good exhaust system to get (I have been told to avoid Magnaflow) that will give me a decent sound at a good price (trying to spend between $1000 to $1200 - less than $1000 if possible!) and perhaps boost the HP a little bit?
2 - Is it necessary to get the/an X-pipe as well? Is this where the added (albeit a small amount) Horsepower comes from? What will I be missing if I DO NOT get the X-pipe (would upgrading just be pointless without the X-pipe?)?
Any advice and education is greatly appreciated. Thanks – CK.
QUESTIONS:
Well forget about the hp gains for the most part, if any it will be unfelt.
I have the Corsa Sports mufflers which do give more sound without droning and sounding like a hot rod.
PROBLEM IS THAT THEY ARE RATHER EXPENSIVE, $1800ish. All stainless steel though so will last a lifetime.
Cheaper alternative being manga flow or flowmaster will sound more vacuum cleaner like and have drone for sure.
Corsa does offer two other options, one being the Extreme which is loud and the Touring which is mild. The Sports lay in between and seem to be the most popular.
I also added the Z06 manifolds and H pipe which does give some decent hp gains and added attitude sound wise.
The audio clips are tough to get the real sound so better off listening to the system in the real world.
look for a used set and your in the ball park dollar wise. Again SS so it will last.
The X pipe will change the sound some and lower the popping on deceleration somewhat.
Any hp gains is from a free flowing design which will also be louder.
Received 2,486 Likes
St. Jude Donor '15
"In honor of jpee"
not trying to be harsh, but your searching skills need some upgrades. the word "search" in the red band above will take you to "advanced" if you select it. then, in the upper left, put in search words and limit to C6 Gen, or Tech.
words like "borla" gives you: http://forums.corvetteforum.com/sear...rchid=32315761
corsa: http://forums.corvetteforum.com/sear...rchid=32315809
then think up your own words to use to get more info. not so hard to do. better than trying to reinvent the wheel.
Drone doesnt bother me much.
Im gonna get electronics cut outs installed soon
reason I bought it 'cause it sounded soooo good.
When I start it up the BMW owner across the street says, "that's the
best sounding car I ever heard.
I just drove it from Michigan to Florida (again) and the so called drone
doesn't bother me at all.
Just love my exhaust system, it's a M6 speed.
Thanks - I shall keep this in mind. It seems that Corsa states no drone - but they are expensive. According to your input, if you are going to get an exhaust - spend the money to get something decent with no drone. What was it that you spent $1500 on - so as I know to avoid this issue you had?
QUESTIONS:
QUESTIONS:
PS: I see you are in the Bay Area - I used to live in Piedmont - so good looking out! Too bad about the A's...
(p.s. - not harsh at all and I half expected someone to tell me to improve my search skills. You were most polite about it - thanks.)
I'll be going the OBX catted header route (go to C6 "tech and performance" forum, then click on "search this forum") and hooking to my stock NPP's.
The NPP's open are perfect sounding to me.
Do not worry about the thread ending, the turn over on this forum is fast. In a few hours your post could be on the second page.
If your on a budget I strongly suggest you try and hear these systems on the car live.
Maybe a car show or fun run in your area.
There is a section in the forum that applies to regional post, try this for some nearby help.
Better safe than sorry and there have been lots of folks that wish they had done just this.
The car may sound great from the outside but how is it inside...you the driver will have to live with it.
Good luck.
Good luck.
St. Jude Donor '15
"In honor of jpee"
You are absolutely kuuur-eckt - I do need to improve my search skills! I shall do this, but I have another question to ask you then...when I have had enough answers from a post that I started - how do I end the thread so as to not have it take replies any longer?
I agree with most fellas on here that Corsa sports or touring would fit the bill. Gonna need to come out of pocket a bit more but you get what you pay for. I have the NPP and love them especially with the mild-to-wild switch. That said, LG long tube headers made the biggest difference in power and sound to be certain. At any rate, get the cat back first and then start thinking about long tube headers after that and the upfront support mods. You'll find many reasons owning this car to WANT to spend your money!
After owning my 05 coupe with BB Bullets for 11 months I can tell you that I wouldn't have it any other way. I just took a road trip from New Orleans to Orlando and back. Yes the drone is noticeable inside the car especially with the top on and windows up, but neither me nor the wife mind it at all. She slept fine when she wanted to.
I couldn't see owning this car without the Bullets. The car sounds like it should. It sounds angry and ready to punch the opposition in the mouth.
QUESTIONS:
QUESTIONS:
