Service Active Handling System
Old 10-27-2012, 10:33 AM
RYK24
4th Gear
RYK24's Avatar
Default Service Active Handling System
For the 5th or 6th time, my 2008 went into "Limp Mode". The Service Active Handling System and Tracking System messages displayed. The Control Module was replaced and I still have this issue.
BTW... I had a PAL (Personal Audio Link) installed; can't recall if the first Limp Mode experience was before or after installation (I'm looking to that).
If anyone can assist with possible scenarios as to why this is happening would be greatly appreciated.
Old 10-27-2012, 11:07 AM
TR-6060
TR-6060's Avatar
I had this happen a couple of times on my early build 2008. Service Active Handling error on DIC with traction control and security lights on (is your security light on?). When I scanned it with AutoEnginuity, it showed a "U1000 Class 2 Data Link Malfunction" under the Body Control Module section. Under warranty dealer restrung wiring to steering angle sensor in steering column which solved the problem.
Old 10-27-2012, 11:09 AM
highping
highping's Avatar
When I had my '09 Coupe, this happened and they had to pull it out of my garage to take it to the dealer. Dealer said that the Control Module was corroded and needed to be replaced.
Old 10-27-2012, 11:27 AM
Dave Carney
Dave Carney's Avatar
Had the same problem on my 2008. Installed the problem solver part GM made for the models with telescopic steering wheel (even though mine doesn't have one) and in the year since, it has never happened again. Do search for the little orange wedge for the electrial connector under the steering column.
http://s680.photobucket.com/albums/v...cpZZ1QQtppZZ24
Old 10-27-2012, 12:31 PM
Get_UmJ13
Support Corvetteforum!
Get_UmJ13's Avatar
I had this problem once on my 07 Vette. I had the control module replaced and it never returned.
Old 10-31-2012, 03:56 PM
Chevy Cust Svc
Chevy Cust Svc's Avatar
RYK24,
Have you been back to your dealership to have this diagnosed again?
Evan, Chevrolet Customer Service
Old 10-31-2012, 04:38 PM
RYK24
4th Gear
RYK24's Avatar
Originally Posted by Chevy Cust Svc
RYK24,
Yes. They replaced the VCIM about 3 months ago and now they are replacing the BCM. They're telling me it may have something to do with the PAL, since this issue didn't start until after the PAL installation.
Rick
Old 10-31-2012, 04:41 PM
RYK24
4th Gear
RYK24's Avatar
Thanks to all for your comments. I'll run these by the dealership and see if they checked the items listed in your replies.
Thanks again... much appreciated!!!
Rick
To Service Active Handling System
Quick Reply: Service Active Handling System
