Old 03-25-2015, 12:54 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Interior How-Tos
Print Wikipost
DIY Fix for "Loose Gas Cap" indicator aka code P0449 w/Pics
Old 10-25-2012, 05:50 PM
JKbride
Support Corvetteforum!
JKbride's Avatar
W. GA Events Coordinator
St. Jude Donor '12-'13-'14-'15
Default DIY Fix for "Loose Gas Cap" indicator aka code P0449 w/Pics
Driving down the road and you see "Check Gas Cap" warning come up on the Drivers Info Center (DIC)...take heart, it's an easy fix and does not take much time or money to repair yourself.
First, check your fuses and your gas cap. The cap should be on good and make sure it's secure. Tank up and drive your car for about 50 miles. If the code does not clear you should replace your gas cap. I purchased one from my local Chevrolet dealer for $22.
Secondly, if after tanking up and replacing your gas cap the warning does not clear, then it's time to use your trusty code reader and see if you can't read and clear the code. If you don't have one you can purchase them at your local parts store for about $50.
Plug it in the OBD adapter located under the driver’s side dash.
Follow your reader’s instructions and read the codes.
In my case I had a P0449 and a P0455. P0449 Evaporative Emission Control System Vent Valve/Solenoid Circuit Malfunction and P0455 Evaporative Emission Control System Leak Detected (gross leak)
I tried resetting my codes, but they would come back within seconds. The next step is purchase a new Fuel Vent Solenoid from your local dealer. In my case it was about $25. GM also recommends an upgraded harness ($30)...but it was not needed, so I will return it.
The Fuel Vent Solenoid is located on the passenger side tank near it’s top and is easy to get to. I removed my rear tire, jacked up the car, placed jack stands and chocks (I'm super cautious under a car).
Once under the car this is what you will see, and I have my finger on the part:
Remove the Vent Hose (it runs to your emissions canister) using a pair of pliers. You can rotate the clamp if needed to access the dog ears to open the clamp.
Unplug the power connection
Slide the Vent Solenoid Assy of its bracket. Although it looks like it would slide towards the front of the car it does not. Simply lift the back of the assy high enough for the dog ear to clear the back of the bracket and slide toward the rear of the car. The pic below shows you how it mounts and the dog ear location.
Put the new Vent Solenoid Assy back on by placing it on the bracket and slide it towards the front of the car. You will hear it click in place. Plug the power plug back in and reconnect the hose.
Here is the new one installed.
Now plug your code reader back in and scan for codes. If they come up hit erase.
This is what you should now see on your code reader. No Codes and the DIC is clear with no check engine light or warnings.
From start to finish the repair took 20 mins. The cost of the parts, including gas cap was about $50 and if the harness is needed it's about $80. If you don't have a code reader add another $50. Only tool needed is a pair of pliers.
In all this is a simple repair and does not cost much in terms of time or money to do yourself.
I hope this helps,
John
The following 31 users liked this post by JKbride:
808_Vette (10-26-2018), 89talon (11-07-2017), AraNe (03-14-2024), Ben101er (06-03-2016), C5 4me (06-08-2020), cartop2 (07-02-2019), ClashBandicoot (08-09-2016), COCO RICK (02-17-2017), corrado (10-14-2015), DRKCYDE (10-13-2018), duckvett (09-24-2015), Euthymicone (07-07-2019), Fed Up (06-21-2021), HK770 (01-04-2016), Itshakes (08-25-2016), joliett (08-15-2019), m.whitmell (07-09-2019), Mark.S+10 (10-06-2015), Mike Green9 (06-06-2020), mikeCsix (09-16-2017), need-for-speed (10-20-2015), nolanrj (03-07-2016), PDsVettes (04-19-2016), rammer71 (06-07-2020), salmonarmvette (10-13-2018), tommyc6z06 (09-08-2022), Turbo6TA (01-16-2017), Vet Interested (01-03-2016), Yaupon (04-19-2016), yeller z06 (02-20-2024), _05C6_ (10-09-2015) and 26 others liked this post. (Show less...)
Old 10-25-2012, 05:52 PM
tclhb
tclhb's Avatar
Nice write up!
Old 10-25-2012, 05:55 PM
Don-Vette
Don-Vette's Avatar
Thanks,well done!
Old 10-25-2012, 05:59 PM
EVRose
EVRose's Avatar
Originally Posted by tclhb
Nice write up!
and I don't think I've ever read here anyone needing to replace a Fuel Vent Solenoid before.
Old 10-25-2012, 06:01 PM
LIE2ME
LIE2ME's Avatar
Received 4,577 Likes on 1,645 Posts
I had the same gas cap message on my 2012. Turns out, unlike most cars, where you need to push the gas cap inward and turn, the 'Vette requires simply that one set the cap on the nozzle and gently twist the cap. DO NOT push at all, just turn clockwise and you're set (my dealer pointed this out).
No error messages since I learned this simple process...
vette6500
vette6500's Avatar
Nice fix!
I assume it fixed the malfunction, but what was the leak code about?
Old 10-25-2012, 06:02 PM
plmkrzy
plmkrzy's Avatar
Thanks for the info. Appreciated!
Old 10-25-2012, 06:07 PM
MikeyTX
MikeyTX's Avatar
Received 2,186 Likes on 1,337 Posts
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13-'14-'15- '16-'17-‘18-‘19-'20-'21
NCM Lifetime Member
you need to contact one of the mods and have this put into the DIYS sticky. It's worth it's weight in gold !
JKbride
JKbride's Avatar
Originally Posted by vette6500
Nice fix!
They are both related to the failure of the Fuel Vent Solenoid. The system was detecting a large escape of fumes...I suspect because the solenoid was in the open position at all times.
This is also why you may get the same code when the gas cap is loose or off because the fumes are freely escaping and not being routed to the emissions canister.
Hope this helps,
John
Old 10-25-2012, 06:12 PM
dvilin
dvilin's Avatar
Received 7,928 Likes on 4,810 Posts
Good info, thanks.
Old 10-25-2012, 06:22 PM
glenB
glenB's Avatar
St. Jude Donor '08-'09 & '12, '14
P0449 is strictly the Vent Valve Solenoid Failure and is not the same as the gas cap which is generally a P0442 Small Leak or P0455 Gross leak
Old 10-25-2012, 06:30 PM
N2TU
N2TU's Avatar
St. Jude Donor '10-'11-'12-'13-'14-'15-'16-'17-'18
Nice write up!
Super Job!
That is what this Forum is all about!...thanks!
Old 10-25-2012, 06:40 PM
RJRSW
RJRSW's Avatar
The gas cap is covered and replaced free by GM under the Emission Select Component Ltd Wty if the vette was delivered less than 8 years ago and has less than 80,000 miles on it since delivery.
Old 10-25-2012, 06:47 PM
Mike's LS3
Mike's LS3's Avatar
Nice write up it will benefit others in the future. That's what the forum is all about.
Old 10-25-2012, 06:54 PM
RO55
RO55's Avatar
Thanks!
Old 10-25-2012, 07:56 PM
not08crmanymore
not08crmanymore's Avatar
Nice write up and the gas caps have a 10 year 120,000 mile warranty on them since 2005.
Old 10-30-2012, 03:25 PM
ANGRY Z
ANGRY Z's Avatar
Im thinking I may need to do this. Keep getting the silly "check gas cap" message on DIC after replacing gas cap with a new one. Thanks for posting up.
To DIY Fix for "Loose Gas Cap" indicator aka code P0449 w/Pics
Old 10-30-2012, 03:52 PM
LS WON
LS WON's Avatar
Old 10-30-2012, 04:09 PM
TCW
TCW's Avatar
St. Jude Donor '06-13,'16-'17, '19
Excellent post. Thanks!
Tom
Globeman
Globeman's Avatar
I replaced mine about a year ago to fix a P0449 Code. They do fail.
Quick Reply: DIY Fix for "Loose Gas Cap" indicator aka code P0449 w/Pics
