Bass & Trebel defaults to center
After every cycle of the ignition.
I just noticed it started today
Did I hit something to make it reset? It's a non Bose, non nav deck.
Have you tried saving the settings with the buttons on the door?
I realize they shouldn't be doing what you say they're doing, just suggesting that might help.
I got my regular FOB set up perfect but I never did mess with the passenger one which is why it defaults to being all screwed up.
Butchn, I've a '12 1LT (non bose, non nav) & had the same issue. I don't recall exactly, but review your owner's manual on radio presets:
When cycling through the XM or radio stations, the manual states to set/choose the station, then choose what AutoEQ preset you want for each, jazz, rock, etc, & then save it. If you don't save the AutoEQ, they all go back to center base & treble after each ignition cycle.
I preset their AutoEQ all to Jazz (it sounds the best to me) & they're always set on Jazz when I start it up now.
Here's what the 2012 owner's manual says. Have you tried the indicated method for saving the settings you've made? The **** they're talking about (below) is the **** on the bottom left of the radio controls.
