Go Back   Corvette Forum > C6 Corvette, 2005 - 2013 > C6 Corvette General Discussion
Register Forgot Password?
Register Search Today's Posts Mark Forums Read FAQ Vendor Directory
Search
General C6 Corvette Discussion not covered in Tech Sponsored by
PFYC
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C7 Parts & Accessories
C6 Parts & Accessories
C5 Parts & Accessories
C4 Parts & Accessories
C3 Parts & Accessories
C2 Parts & Accessories
C1 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 10-09-2012, 12:45 PM   #1
tim414
CF Senior Member
St. Jude Donor '12
Support Corvetteforum!
tim414's Avatar
Default White Film on Dash
To begin; YES, I DID a search and came up empty....maybe using wrong search words....don't know. I started there (w/search) because it seems like I have read something here in the past regarding this issue.
There is a white film on the dash of my car and it is also appearing on a few places on door panels as well.
Does anyone know what this is or how to clean it off? It's definitely NOT dust.
It seems like the dash/door material has bled or emitted this film. The dash is black so it really shows up. I have been meaning to take care of it, but wanted to post here and see if any of you guys have had this experience/happen before and what cleaner (or whatever) it took to safely remove/clean it off.
It seems like I did see something here in the past about this. That's why I did a search first but came up empty.
I sure would appreciate any help or reccomendations from anyone, especially if you have came across this issue before and what is done to correct it.
To add: it sat up nearly all summer (mid-May to early August) because of having wheel issues and needing to be refinished. This is when this occured.
Thanks in advance.
BTW, it's a regular 2LZ....just like a 1,2 or 3LT like I had before.
Tim
tim414 is offline   Reply With Quote
Old 10-09-2012, 12:52 PM   #2
JimTN
Moderator
JimTN's Avatar
Outgassing of the materials in the dash. Got it on the dash, glovebox door, inside car doors in my new 2012 C6. My best recollection is the problem will eventually lessen and go away. Just wipe it off with some detailing liquids.
It's fairly common.
JimTN is offline   Reply With Quote
Old 10-09-2012, 12:53 PM   #3
RO55
CF Senior Member
RO55's Avatar
Regular mild soap & water will take it off. Door panels it's usually where you hands or arms touch. It's normal. I use Mcguires natural shine after cleaning. It gives it a fresh from the factory look - not greasey. After using Mcguires it happens MUCH less.
RO55 is offline   Reply With Quote
Old 10-09-2012, 01:25 PM   #4
JoesC5
CF Senior Member
I use Aerospace 303 Protectant in their 16 oz spay bottle. Spray on a rag and wipe down the dash and door panels. You can find it at NAPA or a local boat supply store. I paid around $13-$14 at the Ski Shack here in Springfield, MO.
JoesC5 is offline   Reply With Quote
Old 10-09-2012, 01:29 PM   #5
Gearhead Jim
CF Senior Member
St. Jude Donor '13
High Tech method-
Wipe away with a cotton towel, damp with warm water.
I do it about every 6-8 months on our 2009, works well.
Gearhead Jim is offline   Reply With Quote
Old 10-09-2012, 01:31 PM   #6
TLS_Addict
CF Senior Member
TLS_Addict's Avatar
I was wondering this too.
TLS_Addict is offline   Reply With Quote
Old 10-09-2012, 01:31 PM   #7
LS WON
CF Senior Member
LS WON's Avatar
I have seen that white powdery stuff on edge of dash cover. It can be removed but it's difficult with the way that windshield is angled. I think I shoved a microfiber into the crevice and wiped it all off.
The Dodge Challenger also gets this white reside all over the top of dashboard.
LS WON is offline   Reply With Quote
Old 10-09-2012, 01:34 PM   #8
peter pan
Life Time NCM #2196
peter pan's Avatar
I use 303 and do it monthly on all my vehicles dashes and all plastic areas, works great and has UV protection to boot
peter pan is offline   Reply With Quote
Old 10-09-2012, 01:36 PM   #9
LS WON
CF Senior Member
LS WON's Avatar
Quote:
Can't use 303 on 2005 Corvette interior as it leaves white streaks. I have to use Jimmy G's cleaner and protectant. 303 is my favorite for my other car and tires.
Old 10-09-2012, 01:37 PM   #10
Seadawg
CF Senior Member
Seadawg's Avatar
Quote:
Originally Posted by Gearhead Jim View Post
High Tech method-
This is my high tech method too
Seadawg is offline   Reply With Quote
Old 10-09-2012, 01:38 PM   #11
N2TU
CF Senior Member
St. Jude Donor '10-'11-'12-'13-'14
N2TU's Avatar
Quote:
Same here...Aerospace does the trick nicely!...
N2TU is offline   Reply With Quote
Old 10-09-2012, 01:39 PM   #12
BadToo
CF Senior Member
BadToo's Avatar
Aerospace 303 for this problem. It will work wonders. Do NOT use Armorall.
BadToo is offline   Reply With Quote
Old 10-09-2012, 01:42 PM   #13
PaulB
CF Senior Member
PaulB's Avatar
I agree, Aerospace 303 seems to have worked for many of us. Usually available at a Boat Shop. I dont know what the real cause is, but in my Corvette, I have noticed it most on the upper door panels close to the glass. I have always guessed it was the salt or the acid on/in my skin. Just a guess ...
PaulB is offline   Reply With Quote
Old 10-09-2012, 01:42 PM   #14
ELP_JC
CF Senior Member
It's a good idea to use a protectant, or vinyl will eventually dry out and crack. Also make sure you always put a windshield sunscreen when car is parked. And tint the windows to decrease heat inside the car while parked. It also helps protect door panels and seats from direct sunlight. Don't forget to condition the leather in the seats too. Good luck.
ELP_JC is offline   Reply With Quote
Old 10-09-2012, 01:46 PM   #15
LS WON
CF Senior Member
LS WON's Avatar
You can get the 32 oz. size. They now also have a 303 cleaner available.
Old 10-09-2012, 01:47 PM   #16
JoesC5
CF Senior Member
Quote:
Or do like I do and leave it in the garage 95% of the time, out of the sun.
Old 10-09-2012, 01:48 PM   #17
MTsVette
CF Senior Member
MTsVette's Avatar
I use 303 protectant on all my interior and engine components. No white areas at all. 303 does give the surface a slight satin sheen appearance vice the original dull look from the factory, but everyone that sees my interior and engine bay loves how it looks. I even have a good friend of mine with an '05 convinced to start using it...
I also use 303 spray detailer for the paint too!! It too has SPF 40...
MT
MTsVette is offline   Reply With Quote
Old 10-09-2012, 03:20 PM   #18
BigJoe
CF Senior Member
BigJoe's Avatar
Check this thread, more than you'll ever want to know about "white dust".
http://forums.corvetteforum.com/c6-c...-interior.html
BigJoe is offline   Reply With Quote
Old 10-09-2012, 03:22 PM   #19
Top_Fuel
CF Senior Member
Top_Fuel's Avatar
Quote:
Search for "white AND dash" in the topic.
Anyway...it's what all these guys are saying. HERE is another big-azz discussion about it.
Top_Fuel is offline   Reply With Quote
Old 10-09-2012, 04:43 PM   #20
tim414
CF Senior Member
St. Jude Donor '12
tim414's Avatar
Appreciate the replies. When I was cleaning it (after it had set up for those months) I was using a microfiber towel dampened with H2O. It did NOT work well. In fact you can see were I did it and half of it is still there. It NEVER sits out in the Texas sun especially during summer months. It's always inside unless I'm out in it somewhere.
I stopped using armor all years ago.
I am going to look for some Aerospace 303.
To Joe: dam, I just drove by the boat place and so I guess I'll go back. The only NAPA around here is 20+ miles one way. Several Auto Zones here though. Seems like they never have what I want unless they order it in. Hate going there.
Does Wally World carry it? One of those close by as well.
Reload this Page White Film on Dash
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Suggestions For Front End Body Protection C-2 Viet Nam Vett C1 & C2 Corvettes 21 06-11-2014 01:25 PM
Anyone Else Have This White Film All Over The Door Panels and Dash With Ebony ? Torch2013C6 C6 Corvette General Discussion 36 03-18-2013 09:55 AM
Emails & Password Backup
Search Engine Friendly URLs by vBSEO 3.5.2
