White Film on Dash
Old 10-09-2012, 04:47 PM
RJRSW
RJRSW's Avatar
Originally Posted by Gearhead Jim
High Tech method-
Wipe away with a cotton towel, damp with warm water.
I do it about every 6-8 months on our 2009, works well.
I just wipe it off with a damp chamois and repeat if it returns. Seems like it barely happens now and haven't seen any sign of it returning since earlier this year.
Old 10-09-2012, 05:04 PM
QUAKEJAKE
QUAKEJAKE's Avatar
Originally Posted by JoesC5
I use Aerospace 303 Protectant in their 16 oz spay bottle. Spray on a rag and wipe down the dash and door panels. You can find it at NAPA or a local boat supply store. I paid around $13-$14 at the Ski Shack here in Springfield, MO.
This, and it leaves a UV protection behind as well as a low luster sheen. Keeps my 38K mile seats looking new.
Old 10-09-2012, 05:07 PM
dvilin
dvilin's Avatar
Received 7,920 Likes on 4,806 Posts
Great product.
Originally Posted by peter pan
I use 303 and do it monthly on all my vehicles dashes and all plastic areas, works great and has UV protection to boot
Old 10-09-2012, 05:20 PM
R&L's C6
Support Corvetteforum!
R&L's C6's Avatar
Received 1,244 Likes on 704 Posts
It seems normal for the Corvette but I have to say, it's the first vehicle I have ever had this happen to.
Old 10-09-2012, 08:08 PM
z06clif
z06clif's Avatar
Originally Posted by LS WON
Can't use 303 on 2005 Corvette interior as it leaves white streaks. I have to use Jimmy G's cleaner and protectant. 303 is my favorite for my other car and tires.
does the same on my 06. I found that Zainos "leather in a bottle" works the best for me.
Clif
Old 10-09-2012, 09:07 PM
Mad*Max
Mad*Max's Avatar
Received 1,494 Likes on 815 Posts
everybody gets it on the C6 - I use Armour All but a very small quantity
Old 10-09-2012, 09:12 PM
tim414
tim414's Avatar
St. Jude Donor '12
Originally Posted by JimTN
Outgassing of the materials in the dash. Got it on the dash, glovebox door, inside car doors in my new 2012 C6. My best recollection is the problem will eventually lessen and go away. Just wipe it off with some detailing liquids.
It's fairly common.
Thanks, I appreciate that. This is a 2010, and first time it's ever happened. I did go check the glovebox after seeing your post, and yes, there ARE spots showing up there too.It's just not as noticeable being a different color from the black dash.
I posted that I have tried a microfiber towel dampened with H2O but it did only a little good, as the film just does not look quiet as heavy in that spot now.
Hard to believe I've had this car 2.5 years now and happened while it was sitting up waiting to get wheels back.
Old 10-09-2012, 09:15 PM
su8pack1
su8pack1's Avatar
Damp cloth works for me, or an interior detailer.
Old 10-09-2012, 09:21 PM
tim414
tim414's Avatar
St. Jude Donor '12
Originally Posted by Top_Fuel
Search for "white AND dash" in the topic.
Anyway...it's what all these guys are saying. HERE is another big-azz discussion about it.
Thank you sir.
Old 10-09-2012, 10:25 PM
florida john
florida john's Avatar
The plastics are oxidizing. You can temporarily clean it off, but it will come back soon. Aerospace 303 is the only stuff that I have found that will eliminate it for a considerable time. Had it on my 2002 FireBird, and 303 eliminated it and I reapplied every year. 303 is more expensive than other treatments, but then it works when others don't.
Old 10-10-2012, 03:35 AM
LS WON
LS WON's Avatar
Clif
Smells the best too like real leather.
Old 10-10-2012, 07:21 AM
Jimmy W1
Jimmy W1's Avatar
A few months ago, I went to Tractor Supply and got a jar of Mink Oil. I have used it ever since on all of my cars.........
Old 10-10-2012, 11:07 AM
  #33
JoesC5
JoesC5's Avatar
Received 1,699 Likes on 1,213 Posts
And it takes no additonal time/labor to wipe down the dash and door panels with a rag sprayed with 303 vs a rag sprayed with water. For the long haul, might take even less time as one dosen't need to wipe down the dash/doors as offen when using 303 vs water.
Old 10-10-2012, 12:13 PM
  #34
PCMusicGuy
PCMusicGuy's Avatar
It never stops as far as I can tell. 75k+ miles and 5.5 years and the film still returns. I recently tried 303 but haven't really seen that it has made much of a difference over water or some other cleaner.
BTW, Ace Hardware usually carries Aerospace 303.
Old 10-10-2012, 02:41 PM
  #35
Jimmy W1
Jimmy W1's Avatar
Try Mink Oil. If that doesn't do it, then I would say that you have used cleaners so much that you have rubbed the color out of the material.
Quick Reply: White Film on Dash
