Go Back   Corvette Forum > C6 Corvette, 2005 - 2013 > C6 Corvette General Discussion
Register Forgot Password?
Register Search Today's Posts Mark Forums Read FAQ Vendor Directory
Search
General C6 Corvette Discussion not covered in Tech Sponsored by
PFYC
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C7 Parts & Accessories
C6 Parts & Accessories
C5 Parts & Accessories
C4 Parts & Accessories
C3 Parts & Accessories
C2 Parts & Accessories
C1 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 10-01-2012, 07:50 PM   #1
Gearhead Jim
CF Senior Member
St. Jude Donor '13
Support Corvetteforum!
Default Power Steering Fluid- 2 GM Part Numbers
The Owner Manual for our 2009 says to use GM #89021184. Today the local dealer only had #89021185, one number higher. The design of the label and bottle shape are different, but the quantity is identical (16 oz) and the front side on each simply says Power Steering Fluid. I didn't get to look at the rear label to see if there are different specs.
So, how do I find out if there any difference in the actual fluid?
Gearhead Jim is offline   Reply With Quote
Old 10-02-2012, 08:28 PM   #2
Gearhead Jim
CF Senior Member
St. Jude Donor '13
Anybody?
The local parts guy says the part numbers seem to be interchangable, but that doesn't mean the fluids are truely identical.
I can't find the 2013 Corvette Owner Manual online, but the 2012 version still shows 89021184 for the PS fluid.
Old 10-05-2012, 09:25 PM   #3
Gene Culley
Platinum Supporting Vendor
Gene Culley's Avatar
One is a quart and one is a pint. That is really the only difference.
__________________
Founder of GM Parts House
Home Of The Corvette Parts And GM Parts Specialist
Please Visit GM Parts House Online or Call 484.949.2099.
Gene Culley is offline   Reply With Quote
Old 10-05-2012, 10:35 PM   #4
Gearhead Jim
CF Senior Member
St. Jude Donor '13
Quote:
Unfortunately, that is not correct.
I have one bottle of each sitting in front of me as I write this, and both are marked as 16 fluid ounces, which is one pint.
The bottles are slightly different shape, but identical capacity.
Old 10-07-2012, 10:33 AM   #5
Gene Culley
Hmm.. perhaps I got the numbers mixed up then. There is an instance where one is a quart and one is a pint. I'll look further into it.
__________________
Old 10-07-2012, 10:36 AM   #6
b4i4getit
CF Senior Member
b4i4getit's Avatar
You don't have to use GM bottled power steering fluid I hope you know. They purchase from another source, bottle it and charge a lot more for it.
b4i4getit is offline   Reply With Quote
Old 10-07-2012, 01:30 PM   #7
Gearhead Jim
CF Senior Member
St. Jude Donor '13
Quote:
There are doubtless many other brands that will work just as well as the GM stuff, and a few that will be worse. The cost difference is not significant for a few pints, so I just go with the GM.
Old 10-07-2012, 01:40 PM   #8
Bill Dearborn
Bill Dearborn's Avatar
I did a Yahoo search on 89021185 and found somebody's order for 89021184 on GM Parts Direct. The web site said it added 89021185 to the person's shopping cart because 89021185 replaced 89021184. GM periodically rolls part numbers for some reason or another. Could be all they did was switch suppliers.
Bill
Bill Dearborn is offline   Reply With Quote
Old 10-07-2012, 02:09 PM   #9
JW@JWMotoring.com
Supporting Vendor
St. Jude Donor '09-'10-'11-'12-'13-'14
JW@JWMotoring.com's Avatar
jmotoring jwmotoring C5ish
looks like they're using Wix fuel filters as their own now
http://forums.corvetteforum.com/c5-g...cam-alert.html
JW@JWMotoring.com is offline   Reply With Quote
Old 10-07-2012, 08:03 PM   #10
Gearhead Jim
CF Senior Member
St. Jude Donor '13
Quote:
Bill
Sounds reasonable, thanks.
Since I flushed my system with the 1184 stuff and have ~1/3 bottle left over, I'll use that for any top-offs required until I do the next flush in about three years. AFAIK, there shouldn't be any problem with the opened-and-recapped PS fluid absorbing moisture from the air, like brake fluid will do in a hurry.
BTW, my steering "flush" is simply the Service Manual procedure, no exotic flushing fluids or machines.
Reload this Page Power Steering Fluid- 2 GM Part Numbers
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Power Steering Fluid csyvarth C5 Tech 2 01-01-2014 09:29 AM
What is the Direction of Power Steering Fluid into the Reservoir on an LT1 Fl Sidney004 C4 Tech/Performance 3 08-22-2013 11:52 PM
'03 Z Power Steering Fluid Equivalent OneCylinder C5 Tech 9 07-29-2013 03:40 PM
Power steering fluid? RatDog C1 & C2 Corvettes 10 01-01-2013 07:24 PM
Power steering fluid Crowhater C6 Corvette General Discussion 11 08-15-2012 12:14 PM
Emails & Password Backup
Search Engine Friendly URLs by vBSEO 3.5.2
