Another battery dead....observations
Well, finally happened.... 2007 original battery died... and all of a sudden at that...
With old battery, DIC showed over 14 volts with engine running .... After replacement with engine running DIC shows around 13.6-13.8 or so....
Question is, with the new battery, alternator is not having to charge at over 14 volts now?... So, would DIC showing over 14V now be a sign of a weakening battery? IE needs more help from the alternator?
Received 2,485 Likes
St. Jude Donor '15
"In honor of jpee"
14+ is normal. even for a new batt. don't worry about it.
What was your original battery voltage with a load? This is the only way to test a battery's true health.
What's your new battery's static
voltage? Know how to check for it?
Might wanna replace your FOB batteries too. (Unless you like being stuck.)
1st Gear
Good Evening All: New to this forum. I purchased by GS on Saturday & picked it up Monday Evening, and by lunch time today the battery was DOA. Battery replaced and all is happy now, but not the way I wanted to start my Corvette experience off.
Interesting how battery and electrical problems start showing up this time of year when the temps drop just a few degrees overnight. My Impala was acting up for a week or two with slow cranking and finally got really slow. I thought it was the alternator since the Sears Die Hard was only a couple of years old. One morning checked the battery cold and it was about 10.5V and after slowly encouraging a start I got about 13V across the terminals. Sears replaced the exactly 3 year old battery for $50 which included prorated return. Not bad. Yep, amazing what those temps do to a marginal part. I remember as a kid replacing starters and generators and batteries and solenoids this time of year.
Received 1,503 Likes
Yes, replaced the FOB batteries a few weeks ago...
Thanks for all the info...I know space is tight but a larger battery would have been a bonus in these cars... the battery is pretty small for sure...
SoCal Events Coordinator
St. Jude Donor '12
Jeepers op, your car is an 07 and the battery is just now going? You should be happy you got almost 6 years out of the thing. I'd be pretty happy if i get that out of my vett's.
Your battery issue is not like many have had where the battery fails pre maturely you got full life out of yours!
Did you use a maintainer to get that kind of life out of it? I keep maintainers on my vetts but did leave the trunk lid open on my 04 and the battery was dead and was never able to recover. It was 3 yrs old.
Received 8,956 Likes
Bill
My 07's battery is still fine @ 5 yrs. 9 months. I've had a Delco battery last 9 years in one of my Corvettes - the guys at the parts store were in shock . No "tender" was utilized either . They sent the battery to Delco.
I did notice the car re-adjusting everything computer wise after the install.... like it was re-learning.... although I am still waiting for my extra 20HP to kick in!!
The battery in my 08 finally went in August. The car sits for extended periods of time during the year sometimes up to 4 to 5 weeks in the winter and it always started without using a battery maintainer. Don't know if a maintainer would have given me a couple of years more battery life but I sort of doubt it. I have only had one battery that ever went past the 4.5 to 5 year lifetime and it was one that I moved from car to car since it just kept going. It was a Delco and lasted 7 years.
Bill
Bill
BTW, sulfation shows up on the terminals, good way to tell your battery is in trouble. Battery testing kits are cheap, good way to keep your eye on conventional battery through electrolyte testing. I mount maintainers in the car, this way it is easy just to plug it in.
