Exactly how bad are aftermarket wheels?
I have 360 forged..... Some issues in the beginning but otherwise ok...... If I had to do it all over again, I would have gotten some used HREs like I did on my R8.......... Btw, from now on, I will always buy wheels from Gerry at wheels for less......absolutely best customer service around...... Trust me on this !
Agree totally. Its not just business for this guy, its a passion. I havent purchased 1 thing from him and he has been a tremendous help in my wheel buying process. You need to talk to him to understand.
I have too, but I had a problem with the XXR wheels I had on my Genesis Coupe. Don't buy anything from that company. Out of round & they would not warranty & they chipped super easy. Whatever they are made from is a super soft material. Unsafe.
Received 2,058 Likes
St. Jude Donor '13
But I think those 30/90 numbers are about correct.
Factory tires seem to have more problems, especially on the GS/Z06.
A poll would be interesting.
You really get what you pay for.
I agree that it depends, but Timex makes a solid though inexpensive product. Some aftermarket wheels are far worse than a Timex....some. Jim is right, aftermarket wheels in general are involved in more than their fair share of problems here on the forum.
After dumping the run flats and dropping a few lbs on each wheel. I found the value of low unsprung weight .
I would not buy after market rims because they raise unsprung weight.
For me it would be conceptually wrong
#33
I never understood why people will replace well made factory wheels, in some cases on the c6 they are forged, and put on cheaply made wheels. Good wheels are more expensive not just because the vendor is gouging you. There is real value in the cost and to sacrifice quality on such an important part of a high performance machine does not make sense. Go cheap on floor mats, not wheels.
#34
Aftermarket rims that weigh the same or less. Yes.
Inexpensive aftermarket rims tend to weigh more which I believe is the topic of this thread
#37
The original post is discussing "replica" or "reproduction" wheels. The term aftermarket is getting confused here. Yes, aftermarket wheels such as HRE, OZ, etc. can be lighter than oem. Big difference between those versuses the cheap, Chinese made replica wheels which are merely for looks.
#39
It's a mod. Your car is instantly worth 5k less.
#40
St. Jude Donor '22-'23
Some first hand experience here... I just got back from a local high performance shop after having my Chrome Z06 Reproduction Wheels mounted and balanced. I have been tracking this thread since it started knowing I was going to do this.
So my wheels were just delivered to my house this morning. I paid just under $1K for 4 wheels from one of the vendors on the board. I quickly unpacked them and brought them down to ADS in Chandler for the install.
I asked the guys who did the balancing and mounting what they saw as far as quality, ability to balance and if they were out of round in any way. They said the quality looks good, they were able to balance them to what they called "zero" which I guess means they are perfectly balanced, but they said at very high speed they noticed where they were just a bit off from side to side. They told me everything will be fine and I should have no issues. The only potential issue would be that I "might" feel a slight vibration at really high speeds. They told me it is unlikely though. They said the wheel is structurally sound and will perform just as good as the factory ones that they took off. I will give them a good test over the next week just to make sure, but on the drive from the shop back to work I was going pretty fast and they were smooth as silk.
The wheels look AWESOME and I couldn't be more satisfied. I don't really plan on having the car up above 150 MPH for long periods of time anyway.
Is the quality compromised over the factory wheels? Maybe just a bit.
For typical "spirited" driving that I do around town is it going to matter? Probably not.
Are the wheels going to "break" and damage the car and cause an accident? Probably not.
Am I happy that I have an extra $1000 in my pocket so I can get a cat-back system? Hell yes!
Cheers!
Cheers!
