Rear tire low air pressure
Old 08-19-2012, 01:31 AM
Red12
Red12's Avatar
Default Rear tire low air pressure
Hi All, Coming home tonight, I got the low tire pressure message for my right rear tire. It read low air pressure, 23 lbs., stop and put in air soon. Luckily, I found a gas station on the Merrit Parkway with free air! I looked the tire over, found nothing, filled it with air and drove home. So far, the tire seems to be holding the air. Has any one had a similar experience?
Old 08-19-2012, 01:51 AM
WAwatchnut
Support Corvetteforum!
WAwatchnut's Avatar
Could be the valve stem - they can unscrew and leak air.
Old 08-19-2012, 02:14 AM
Jimmy W1
Jimmy W1's Avatar
Yep....if you don't find a nail, probably something wrong in the valve or around the valve. Spray some soapy water around the valve- then move the valve around a little and see if you see any air coming out.
Old 08-19-2012, 04:03 AM
AORoads
AORoads's Avatar
Received 2,481 Likes on 1,944 Posts
St. Jude Donor '15
"In honor of jpee"
before you do that, this morning use your hand held gauge to test the tire pressure now in there (presumed: you put in the difference betw. 23lbs. and about 30 or so). if it is too high, it could be the tire pressure sensor itself is going bad. but the other advice above is good if the tire is up to correct pressure this morning.
Old 08-19-2012, 07:14 AM
CaryBob
CaryBob's Avatar
I've had three rear tires replaced in the last ten months. All with foreign objects that I could not spot while the tire was on the car. In two cases the tire lost 1-2 pounds a day, but in the other case it was losing only a pound every 2-3 days. They went "flat" very slowly. I've learned to check the cold pressure every day when I suspect a leak.
Old 08-19-2012, 07:23 AM
DHB820
DHB820's Avatar
St. Jude Donor '09
I had this problem in the rear drivers side tire. Tightened the valve stem and that corrected the problem.
Old 08-19-2012, 07:49 AM
Aviator
Aviator's Avatar
Cruise-In I Veteran
Cruise-In II Veteran
Cruise-In IV Veteran
I was losing 5lbs of air every two weeks in my left rear. Couldn't find any nail, but sure enough I had one - close to the wide wall so the tire was trash with only 500 miles on it. Got it replaced for free under the GY road hazard warranty. Tire may be crap but the warranty is excellent.
Old 08-19-2012, 10:53 AM
gcope63
gcope63's Avatar
I had a slow leak on my DD that was dropping about 10psi a week.. I took it in twice before they could find the issue! They finally tracked it down to a bead leak.. Once they pulled the tire and cleaned the bead the leak was gone.. Not sure how it occured since I had not had the tires off for a long time but that was the fix..
Gary
Old 08-19-2012, 11:50 AM
cclive
cclive's Avatar
Sometimes it depends on the position of the tire when the car is parked. If a nail is squeezed a particular way, the hole may leak more or less.
Old 08-19-2012, 11:58 AM
John Harry
John Harry's Avatar
St. Jude Donor '10-'11-'12-'13-'14
But don't over-tighten it. Spec is 62 inch-lbs, which isn't much.
Old 08-19-2012, 03:41 PM
Mad*Max
Mad*Max's Avatar
Received 1,500 Likes on 817 Posts
have you been checking the cold tire pressure recently to
know if there has been a sudden drop?
Old 08-19-2012, 04:41 PM
Red12
Red12's Avatar
Default air pressure
Hi guys, thanks for the replies. While out in the daylight, I found the culprit: A nail. Any advice about repairing the tire? Is this covered by Goodyear road hazard? What about those beautiful rims? Should I worry?
Old 08-19-2012, 06:50 PM
BEZ06
BEZ06's Avatar
Take it to your local Discount Tire - they fix flats for free.
As long as it's in from the shoulder far enough then it's repairable with a proper plug/patch and it will retain it's speed rating.
I just found a nail in the RR tire on the ZR1. I've taken several Z06 and ZR1 punctured tires to my local Discount Tire, and they always have done a great job being very careful with the wheels - and with the recent repair of the tire on my ZR1 Comp Gray wheel you can't even tell it had been worked on.
It's free - but I always slip the tire guy a nice tip!!
Bob
Old 08-19-2012, 07:19 PM
cclive
cclive's Avatar
Bob
With a Z06 and a ZR1, there would probably be a little grumbling if you didn't give them a tip...LOL....oh well, that just goes with the territory!
To Rear tire low air pressure
Quick Reply: Rear tire low air pressure
