As all the sheep in the pasture said when he passed by....Baaaaaaaaaad' 'Looks great you should be proud, I love the VY with those rims hope to see you on the road one day.
Old Gator Save the wave
St. Jude Donor '08-'09-'10-'11-'12-'13x3- '14-'15-'16-'17-'18-'19-'20-'21-'22-'23
Originally Posted by Random84
How much weight did the turbo system add?
I don't think very much since the mufflers were removed but with the intercooler/slave oil pumps and plumbing, I'm guessing maybe 75lbs.
Thanks Gator
Originally Posted by R&L's C6
Originally Posted by peter pan
Very nice
Originally Posted by Sunset-C6
Moron alert..............
Originally Posted by S'vette
is there any more lag than a normal turbo setup? would that be too much power for an auto?
i'm guessing yes, there's going to be a touch more lag than if the turbos were mounted in the engine bay. a lot more heat though also. but with 400hp base, you really don't think much about it.
That being said, when they do "spool" up, your smile is priceless My motor head friend from SD called the trip around the block I gave him "Death Ride 2012".
When turbos spool up on an engine like the LS2/3, it absolutely blows your mind...... and your pocketbook should a cop be nearby.
Originally Posted by ScottJ03
Now let's see you drive it, Chicken. Is that upgraded suspension, NOT Those brakes works great on maybe a base car.... LMAO. Don't forget you have to stop....
ahhhh.... didn't take too long for the doucher-haters to show up.
