Cleaning GS wheels? Brake dust!
I have the chrome wheels on my GS. I use Griot's Chrome Wheel Cleaner and the brush like Auto Geeks. I also use a white brush that was part of griot's wheel cleaner kit. I do this every time I wash the car. Also use chrome polish or metal polish and wheels stay pretty good.
Rejex or Armor-All Wheel Protectant makes cleaning easier but, I gave up on cleaning.
Instead I put on Hawk HP+ pads, that actually make more/pure black dust, and a new set of matching Centennial black wheels.
With dust/wheel color matching, clean or dirty they look the same!
Soap and water, sponge, Daytona brush after each ride. Electric leaf blower and small Micro fiber towel. Put car away, and repeat often.
I also have this problem. I have used Rejex on them and wipe them down every week. Do a full cleaning of the wheels about every three weeks. Ceramic brake pads will help reduce the brake dust, but I am not ready to replace them until they are worn out.
There is no magic solution for you.
Between full up wheel washing every couple months or so, I wipe the chrome wheels off when they are cool after each drive with a damp paper towel sprayed with a couple spritzes of Mothers car detailer.
The repeat often thing is the key. I can drive my car 50 miles and if I've had considerable stop and go they'll be filthy. I just clean with a damp microfiber cloth then dry with another microfiber. As far as the barrels go, I took a long paint stick and glued two sponges to it. This skinny tool will get into the back of the barrels with soap and water and works great but once a year in the winter I'll pull each wheel and give them a real good cleaning.
I use Sonax, it works very very good. Just spray it on and wait a few minutes until it turns the recomended color and hose off with just water. It cleans everything just like new without even touching the wheel. It removes all the brake dust.
Bottom line is change pads or just clean the wheels and tires every other day.
#35
Armor All Wheel Protectant works very well on my polished rims though I only treat the exterior. I find it does not work that well on painted rims and don't know what it does on chrome.
#36
Supporting Vendor
St. Jude Donor '11,'13
Carbotech 1521 will solve the problem. Low dust 100% non crossive and stop like stock if not better.
The Carbotech™ 1521™ is our high performance street compound. The 1521™ compound is known for its release and modulation, along with unmatched rotor friendliness. 1521™ is also a very low dusting and low noise compound with an excellent initial bite. This compound's excellent linear torque production provides incredible braking force without ABS intervention. Carbotech™ 1521™ operating range starts out at ambient and goes up to 800°F (426°C+). 1521™ is suitable for ALL street cars, perfect for your tow vehicle or fleet vehicle. Carbotech™ 1521™ is NOT recommended for ANY track use.
__________________
Adam Adelstein
Amp’D Autosport.com
Internet's largest retailer of Carbotech Performance Brake Pads.
PH:216-780-8825.
Email: sales@ampdautosport.com
Web Site & Direct ordering http://ampdautosport.com/
All major CC and Pay Pal accepted.
Check out Promo code:z28
Adam Adelstein
Amp’D Autosport.com
PH:216-780-8825.
#38
Received 1,511 Likes
No-IL Events Coordinator
C6 of Year Winner (appearance mods) 2019
2018 C6 of Year Finalist
St. Jude Donor '12-'13-'14-'15-'16-'17-'18-'19-'20-'21-'22-'23-'24
Rejex, California wheel duster.
Occasionally an old face towel with a spriz of glass cleaner.
Sometimes pressure wash rinse.
#39
Former Vendor
They do get into smaller areas, but never found the Daytona Brushes to miss spots on Vette wheels specifically.
#40
1 Post
St. Jude Donor '12-'13-14
http://www.autogeek.net/wheel-woolies.html
