Grinding/Marbles Noise When Accelerating
Old 07-09-2012, 06:44 PM
AlphaBravo
AlphaBravo's Avatar
Default Grinding/Marbles Noise When Accelerating
I have a 2009 Z06 that makes a strange noise when accelerating normally from a stop. As I let out the clutch and the vehicle starts to accelerate, there is a sound that I would describe as a grinding or like a bunch or marbles hitting each other. If I keep the RPM up higher, the sound doesn't seem to happen or it not as bad. It usually happens under about 1000-1200 RPM. Any idea about what could be causing this sound?
Old 07-09-2012, 06:54 PM
R&L's C6
Support Corvetteforum!
R&L's C6's Avatar
Received 1,250 Likes on 706 Posts
Mine does the same thing. I was told it was normal noise from the torque tube.
Old 07-09-2012, 06:55 PM
mforman42
mforman42's Avatar
Totally normal. It's the torque tube/drive shaft interaction.
Old 07-09-2012, 08:56 PM
2006c6keller
2006c6keller's Avatar
Default Check exhaust manifo clamps.
My C6 06 A6 F55 made "jingling" noises since I had it new. I took to dealer and mentioned about a noise in bell housing area. Here is what they did, replaced the harmonic balancer, the "jingle" still there. I took a broom stick and poked around the bell housing area and heard the "jingle" on the exhaust manifo (headers) area to the tail pipes. Well, the clamps between the pipes were loose since I got the car new. I tightened the clamps up AND the "jingle" is gone. Yea!
Old 07-10-2012, 12:12 AM
Zoxxo
Zoxxo's Avatar
Originally Posted by mforman42
Totally normal.
Your use of the word "marbles" is a dead give away
The Z06 is just chock full of noises that you don't normally hear in a car. This is one of them.
Z//
Old 07-10-2012, 12:49 AM
Rebel 1
Rebel 1's Avatar
The clutch throw-out bearing is rattling on the splines because the trans is in the rear. C5's did this as well. Keep your RPM up a little higher as you said. Do a search on this. Normal.
Old 07-10-2012, 05:56 PM
AlphaBravo
AlphaBravo's Avatar
Thanks for the responses. I'm glad to hear that it's "normal."
Old 07-10-2012, 09:39 PM
chsia
chsia's Avatar
I have a 2012 GS and it has the same noise. Did a bit search, all said it is the infamous "Marbles in a can" syndrome of Corvette since many generations ago. Wonder why GM has not fixed it?
Old 07-10-2012, 10:12 PM
Mike's LS3
Mike's LS3's Avatar
Have the same "marble noise" on my 08 LS3 since it was new. Now with 49k miles the noise has remained the same. It seems to be a little more audible after driving for awhile and the components heat up. When its cold I do not hear it. Service Tech said it was "normal".
Old 07-10-2012, 10:20 PM
R&L's C6
R&L's C6's Avatar
Exactly the same with mine.
Old 07-10-2012, 11:43 PM
kp
kp's Avatar
Nice thing about buying a new 2012 GS is it makes all the familiar noises like my '08 with 50k Miles did. The driveline rattle on takeoff and at idle, the top popping, interior plastic creaking and the famous LS engine 'cold engine knock' below 100* oil temp.
But it smells and drives like new otherwise
Old 07-10-2012, 11:47 PM
bearphoto
bearphoto's Avatar
SoCal Events Coordinator
St. Jude Donor '12
Dang, I'd have said to check the rear axle nuts for proper torque or the end links in the rear suspension. I dont recall this noise in my 09 Z or my 09 Coupe. Maybe its because the radio is usually quite loud!
Old 07-11-2012, 12:26 AM
brooklync5
brooklync5's Avatar
its totally normal and nothing to worry about... all c5-6's do the same... so did my cousins gto and ws6 trans am
Old 07-11-2012, 11:07 AM
JoesC5
JoesC5's Avatar
Received 1,699 Likes on 1,213 Posts
I think it's normal that some have the noises and some don't. My 20,000 mile 09 Z06 dosen't have the grinding/marble tranmission noise.
Old 07-11-2012, 12:01 PM
Thrash
Thrash's Avatar
Just to be sure, this wouldn't be from using an octane that was too low?
Old 07-11-2012, 02:33 PM
PittMD1
PittMD1's Avatar
Maybe I need to put more miles on my 2012 GS (~3600) but I don't hear any noises.
Old 07-11-2012, 02:41 PM
Jimmy W1
Jimmy W1's Avatar
Just put a couple drops of oil on the chipmunk's wheel under the hood and everything should be fine. Be well...........
To Grinding/Marbles Noise When Accelerating
Quick Reply: Grinding/Marbles Noise When Accelerating
