You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
MSM '06 415ci LS3 510rwhp, RPS, DeWitts, Pfadt Coilovers, MGW. Full 2012 GS body and interior conversion C6Z Exhaust
Spring Mountain x4
Leather by DSV
Powdercoating by Mike
DD 05 Silverado Z71
'89 Coupe - for Brody
Gone now but not forgotten:
Sebring Silver '97 LPE SC
Mille Miglia Red '73 L82 Coupe
Daytona Yellow '70 L46 Coupe
The question everyone is trying to ask is "did you open up the system" and by that did you remove the calipers from the car, did you crack open brake lines or any part of the system that exposes the brake fluid.
We know you lifted the caliper off the rotor to replace the rotors but you don't have to crack open the system for that.
If you did open up the system, then you have not completely bled the air out of the system. If you did not crack open the system then something else is going on. Its almost always an air in the line problem once you crack open a line or remove a caliper from the car (not just its mounting location).
Its weird that the brakes improve when warm though. If air in the lines is the problem, that would not improve with time and/or heat. In fact heat would generally make the problem worse.
That what was puzzling me too, But the consensus is to bleed again
So is the pedal soft, or do the pads just not grab?
Soft pedal, then re-bleed.
I replaced the stock pads on my C5 with Hawk HPS, and did the bedding procedure. When I first hit the brakes, before bedding, I almost went right through a red light...
They got much better after bedding, but still not as good as the stock pads when cold. They have now been on for a couple thousand miles, and seem to be improving, but still need some heat in them to have the same feel as the stock pads. With a lot of heat they are much better.
make sure you didn't put the left side on the right side. I did this one time. make sure the bleeder is on the top. If the bleeder is on the bottom, you can't get the air out.
LOL They are on right...
I never let the reservoir run dry while flushing so why would I need to Bleed the ABS?
