Drivers seat problem
Old 05-17-2012, 10:17 AM
jjnitrox
jjnitrox's Avatar
Default Drivers seat problem
Hi Guys:
I have wrote before about this issue but still I have not been able to solve this. My drivers seat from my 05 vette does not work. It will not go back & forth or up or down. I have tried straping the connectors,changing the switches(I interchanged the switch with the passengers side and nothing(passengers side is working perfectly). I checked the fuses and are working good. The motors seemed to be ok. I have read that there is a seat module. can anyone help out on how to check this or is there any way to slove this?. I put a relay to to the connector and power the motor it will go back and forth I do not want to do this because it damage something. At this moment the seat does not have any motion execept for the lumbar support and side bulges. Please help.
Old 05-18-2012, 01:22 PM
Gearhead Jim
Support Corvetteforum!
Gearhead Jim's Avatar
Received 2,046 Likes on 1,358 Posts
St. Jude Donor '13
I'm no help, but here's a free bump and maybe one of the experts will come up with something.
A good dealership (yes, there are some) can probably fix it for you but it will probably be expensive.
Best of luck to you.
Old 05-18-2012, 04:24 PM
dgrant3830
dgrant3830's Avatar
Wounded Warrior Escort '11
I've not taken apart my C-6 seats but the C-5, the SCM is mounted up under the driver's seat itself. On the C-5, its prone to problems with the seat to car interface connectors having connection issues. Since they are probably similar to the C-6's, I would be looking there first.
Old 05-18-2012, 09:10 PM
Kenny94945
Kenny94945's Avatar
Maybe no help but......
Yes there is a seat module/ computer under the seat.
Not sure how to test it.
It is tied into the easy exit circuits.
I had mine replace.
Do note if you have telescopic wheel you need a Tech II to setup the module for that option.
This componet and instructions are in the service manual.
Old 05-19-2012, 10:25 AM
Silverado Desperado
Silverado Desperado's Avatar
I had mine replace.
Do note if you have telescopic wheel you need a Tech II to setup the module for that option. '
Are you saying if the seat module is changed out the telescopic wheel will not work at all without Tech 2 to turn it back on?
Or are you saying Tech 2 needed for telescopic wheel memory function to work again?
So if the module is replaced will the telescopic wheel work, but just not the memory recall function? Or none of the telescopic wheel will work at all unless turned back on using Tech 2?
I am about to replace the module and don't mind if the memory function of the telecopic wheel does not work, but would like to know if I replace the module will the telescopic function work at all, or it won't work until Tech 2 turns it back on.
Old 05-19-2012, 12:57 PM
dgrant3830
dgrant3830's Avatar
The SCM controls the telescoping steering wheel in the C-5's for sure. I'm guessing that it also does in the C-6
Old 05-19-2012, 03:34 PM
Jimbeaux
Jimbeaux's Avatar
I had the same problem on my 05 recently. It was loose wiring at one of the connectors. The connections were fine but there was a loose wire going into one of the connectors. The dealer fixed
Old 05-21-2012, 01:21 PM
jjnitrox
jjnitrox's Avatar
Thanks guys for all your help. I still have the problem. I guess I'll end up at the dealership.It will cost me a arm or leg but that's the price for having a corvette.
Old 05-21-2012, 02:09 PM
Licit
Licit's Avatar
Maybe you'll get lucky and it will be an easier fix than expected. Every once in a while someone has a good experience at the dealer, hope you do.
Old 05-22-2012, 06:09 PM
jjnitrox
jjnitrox's Avatar
Thank you man
Old 05-22-2012, 06:14 PM
orca1946
orca1946's Avatar
My C 6 has memory probs. Some times it moves to the right spot others it does not???
Old 08-15-2012, 08:31 PM
jjnitrox
jjnitrox's Avatar
It was a scm problem.I replacet it and vuaaala. perfect again
Old 08-15-2012, 09:38 PM
HorsePower Junkie
HorsePower Junkie's Avatar
St. Jude Donor '20-'21-'22-'23
It was a scm problem. I replacet it and vuaaala. perfect again
Does "scm" mean seat control module??? Did you only replace one part? Was it plug and play without having to do anything else? Did dealer have to put a Tech II tool on it and program it to see the new part?
Please look on the service ticket or parts dept receipt and let us know what the Part Number or Part Numbers are thet were replaced please.
Old 08-23-2012, 09:10 AM
U DREM 2
U DREM 2's Avatar
St. Jude Donor '12-'13
Would like a part number for the seat control module.
Old 09-22-2012, 12:00 AM
timbob99
Cruising
timbob99's Avatar
Hoping you (or someone else) can answer some of the questions at the end of the thread. I'm having a similar problem. Seat/steering wheel telescope will sometimes work momentarily when I first turn the car on, then stop working. I noticed before it got this bad that it would sometimes take multiple presses of the memory button for the seat to move fully into position. So, sounds like a bad module.
I'm hoping to replace it myself if it isn't too complex, so any further info would be helpful (esp. the question about whether the Tech 2 is needed to get things working again).
Any info (with specifics) would be much appreciated!!!
Old 09-22-2012, 10:21 AM
U DREM 2
U DREM 2's Avatar
I did replace my memory module, but the problem was the two power wires to the module. I order the a new memory module for around $ 100.00 plus shipping. When I took the seat out to replace the unit, that is when I found the two center wires (power) were broken. So I placed the unit and fixture the two power wires and my seats work. A Tech 2 reprogram is needed to make the memory work.
Old 09-22-2012, 02:40 PM
irok
irok's Avatar
p/n 15296303.driver seat module. Dan
To Drivers seat problem
Old 09-22-2012, 10:03 PM
2006c6keller
2006c6keller's Avatar
If they replace the moduel OR the seat motor assembly, you NEED TO REROGRAM FOR TELESCOPING STEERING WHEEL ON THE C6! I've had them forget twice!
Old 09-22-2012, 10:46 PM
U DREM 2
U DREM 2's Avatar
The telescopic wheel will work at all unless turned back on using Tech 2. Also the memory seat will not work until you reprogram it.
Old 02-18-2013, 05:43 PM
timbob99
Cruising
timbob99's Avatar
Just thought I'd update my issue...finally got around to pulling the seat out (wasn't in too much of a hurry since it was adjusted fine for me and no one else drives the car), and discovered what appears to be the ground wire to the seat control module was broken. Of the three plugs going into the module, it was on the center plug, which has 2 wires (a black and a red/white, so I'm guessing that's the power to the module...the red/white was also partially broken, hanging on by just a few strands of copper). I think I was lucky that the seat would move intermittently, presumably because the wire would sometimes make good enough contact. If not, I wouldn't have been able to move the seat to access the anchor bolts.
I ordered a new connector (after much searching, found it on Amazon for much cheaper than anywhere else, AC Delco part # PT159 or GM Part # 12101888), so hopefully when it arrives and I install it, problem will be solved.
Quick Reply: Drivers seat problem
