Found a small oil leak.
Pulled my car out of the garage today to wash it. Noticed a small amount of oil on the garage floor, maybe 2 drops. It seems to be towards the back of the engine but I could not find any leak from up top. I cant get under the car at the moment to get a better look. The car was sitting for a couple of weeks since the last time I took it out so it doesn't look like a major leak but still a leak none the less. Anyone know where it might be coming from? Rear seal maybe? I know oil can travel along hoses and such before dripping but I don't see or smell any oil smell in the engine compartment. Again I could only see from the top. Thanks for any help.
/I also look like I may be developing one though nothing has hit the ground it has the sweat stains showing on the pan.
Fortunately I have drive train warranty til Dec.
CF Senior Member
I wouldn't panic at this point. When you can, get under the car and see if if you notice anything obvious...try to locate the source. If you don't find an obvious source of the leak I'd clean up any oil and grime under the car, check your fluid levels, drive the car more often and keep a clean sheet of cardboard underneath when you park it. See if the leak persists and if you can better locate where it's coming from. Have you changed motor oil or any fluids recently?
Oil pan gasket leaks are fairly common on the C6's.
I took my Vette to the dealer to have it checked out recently.
My oil pan gasket was leaking, and there were 8 Vettes in line ahead of me to have their oil pan gaskets replaced.
I decided to wait until this summer to have it done, right before the drivetrain warranty expires.
Take yours to the dealer to have it inspected.
You may get a free oil change out of the deal.
here's what you do
get under car with light, get at just the right angle so that you can see the front oil pan bolts (closest to the fan) and see if they have oil on the bolt heads. If so, you have a gasket leak. eventually stains the pan and drips to the floor where it collects at the back of the pan usually from the drain plug itself. probably 3 drops a year. nothing to panic over and typical of certain C6's (usually automatics, and 2007 seemed to be the worst year for it). It's a big job to replace it, which I won't detail here. A few who had it replaced said the leak came back later.
If the oil is coming from the back of the motor there was a TSB about that and is a different issue altogether. I'm betting it's the pan gasket though. If you decide to live with it just keep a can of brake cleaner on hand at each oil change. If you do it yourself that is.
Yeah, I haven't hit full panic mode yet but it's always unsettling finding any kind of oil on the garage floor. I haven't changed the oil yet since the car was in hibernation but I actually just made an appointment for next Saturday. My other concern is I just made an appointment with Caravaggio in Toronto next week and I'm driving there. So now I'm a little concerned about taking the car on an 8 hour drive. Do you think it's ok to drive?
I'll bet, there's nothing at all to worry about.
Received 2,057 Likes
St. Jude Donor '13
A year ago our 2009 coupe had a slight seep around the pan gasket, dealer retorqued the pan bolts and added dye. As of last Fall, no leak visible to the naked eye or black light. I'll be taking another look this summer.
The Consigliere
Received 5,458 Likes
It has an oil pan. Just a different type of oil pan b/c of the wet sump system. My '06 Z-06 developed an oil pan gasket leak. Dealer fixed under warranty and I never had another problem with it.
The dealers seem to replace the gasket when it could be all that is needed is to tighten the bolts.
My neighbor had the same thing and the dealer wanted to change the gasket for big bucks (read that as "no warranty"). I put her car up on stands and tightened the pan bolts. Guess what, the leak disappeared.
At the point i'm just concerned about driving 8 hours with it next week. I wont have a chance to have it looked at before my trip. When I have the oil changed next Saturday I will have the tech re-torque everything. Maybe I will get lucky and that will work.
dude.. you can drive it. youre seriously getting worked up over nothing. you could drive it cross country and be fine. twice. cars drip oil sometimes. even our vettes.
if you dont want to take it, then dont. but countless people here have advised you that youre fine.
dont lose any sleep over it. enjoy the trip and drive your car more.
Received 2,186 Likes
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13-'14-'15- '16-'17-‘18-‘19-'20-'21
NCM Lifetime Member
