** New Product, C6 Cup Holder Insulator **
#41
1 Post
I have had mine installed about a month now and I can tell you it REALLY does work! I also have the console one too and it too makes a HUGE difference. Thanks for a great product that is so easy to install & makes such a big difference.
#43
Thank you for posting Robert, we appreciate it
#45
Picked mine up this week along with a replacement front plate mount (I live 20 mins away from Top Flight) & I like the insulator, works as advertised, but I think it should be 1/2 as thick & it'd still work.
The bottles I put in the holder now start to tip over when taking off from a stop due to less depth in the already no so deep void.
#48
#49
Still a great product, don't get me wrong.
I think it could be made 1/2 as thick & still work as advertised to keep my, or others, Coke bottles from toppling, IMO.
#50
I bought the cup holder insulator from Top Flight Reproductions and it works as advertised, significantly reducing the heat's effect on a cold beverage held in the cup holder.
It fits perfectly, and looks OEM.
#51
Got the dual cup holders but I had already cut some silver backed muffler tape strips for the console bottom and the OEM cup holders. Cools better but still not enough not to utilize the added cup holders. Damn ChevyInc should have better insulated the drive tunnel in the first place. These (are) grand touring cars aren't they? Über sports touring machines? If they were only track cars with pull string door handles a la F40s, with no carpets or roll down windows that would be one thing but they're not! Sheesh!
#53
#54
*New Product* C6 Cup Holder Insulator
** This product fits all C6 Models 2005 thru 2013 C6/GS/Z06/ZR1 **
Are you searching for a low cost and easy method to prevent your cold drinks from boiling over? Our C6 Cup Holder Insulator will help keep your cold drinks cold longer? Reduce your cupholder area temperature to a more manageable level by using our easy to install C6 Cup Holder Insulator.
Installation is just a matter of pressing the Cup Holder Insulator into place. Laser cut for a perfect fit, 1/4 inch insulation covered in Black Neoprene Rubber for easy cleaning and a clear plastic pull tab for easy removal. Experience a noticeable reduction in temperature with an easy to install and inexpensive alternative.
ORDER HERE: http://www.topflightrepro.com/corvet...products.shtml
Simple Installation
Slide Insulator rubber side up into cup holder area
Press down
And Done!
Simple Installation
Press down
And Done!
#55
Received 1,875 Likes
2020 C8 of the Year Finalist - Unmodified
Just ordered a set for the new Vert.... also ordered the console insert too.
Hopefully, it knocks down a significant amount of the heat. I may wait to install them another month or two from now when it gets a little warmer.
#56
http://www.topflightrepro.com/corvet...e-frames.shtml
#57
Thank you for the order Richard I noticed that you have the 60th anniv 427, did you know that we have license plate frames for that
Thanks,
#58
