** New Product, C6 Cup Holder Insulator **
*New Product* C6 Cup Holder Insulator
** This product fits all C6 Models 2005 thru 2013 C6/GS/Z06/ZR1 **
Are you searching for a low cost and easy method to prevent your cold drinks from boiling over? Our C6 Cup Holder Insulator will help keep your cold drinks cold longer? Reduce your cupholder area temperature to a more manageable level by using our easy to install C6 Cup Holder Insulator.
Installation is just a matter of pressing the Cup Holder Insulator into place. Laser cut for a perfect fit, 1/4 inch insulation covered in Black Neoprene Rubber for easy cleaning and a clear plastic pull tab for easy removal. Experience a noticeable reduction in temperature with an easy to install and inexpensive alternative.
ORDER HERE: http://www.topflightrepro.com/corvet...products.shtml
Simple Installation
Slide Insulator rubber side up into cup holder area
Press down
And Done!
Simple Installation
Press down
And Done!
Hi Peter, the center console insulation part that I picked up from your Carlisle booth last year worlds great! This cup holder insulator looks to be equally effective. Will you be selling them at Carlisle this year? I'd like to pick one up there.
Thanks!
Hugh
Thanks!
Hugh
Best Regards
Peter C.
#36
Simple Installation
Press down
And Done!
Simple Installation
Press down
And Done!
#38
