Looking for a nice set of tires at a fair price. What are your experiences
So my buddy has stock C6 tires on his C5 and is in need of new rubber. He commutes his car and doesnt RACE at all. He is looking for a tire that is good in the rain and has good life. Doesnt care about the performace piece for the fact he doesnt race and realizes any tire in the 18/19 size will be suitable. What is the best bang for the buck tire out there. Run flat is not an option. To harsh of a ride.
Depending on which brand tire, Non run flats are anywhere from 7-8 LBS Lighter than Run Flats which makes big difference in un-sprung weight.
If he's simply looking for the best price ( bang for the buck ) there are numerous choices.
But using the car to commute, IMO, is more reason to get Run Flats.
For his driving use, I also recommend the Michelin A/S.
Not All Run Flats necessarily equate to a harsh ride.
My Michelin A/S Run Flats give an amazingly comfortable ride.
Do some research before deciding
To each his own and just my 2 cents
I run Hankooks during the rainy season. they have great traction compared to GY runflats. He can get a great price at Americas Tire. I got mine in San Ramon but I am sure there is one around Tracy or Stockton. I still run my GY RFs when I do a lot of out of town cruising and there is major difference in ride quality between the two. Hankooks ride really nice and I have run mine through two seasons and they still look like new.
I had Michelin AS ZP's on my 2001 C5 convert and I got caught in a heavy downpour for about 100 freeway miles coming back from Vegas and they were rock solid and was doing 70+. They are so much quieter than the good years were.
When I sold the car they had 25k on them and still looked new. They are for certain going on my new vette when it needs tires.
I would go with Nitto Invo is he is wanting cheap or the Firestone Wide Oval, otherwise my two top choices are the Michelien SS and Nitto Invo.
and as said the comment on run flat being harsh is correct, they are a heavier tire and have alot stiffer sidewalls than the normal non-runflat version of the same tire.
The ONLY difference is price and you're right there is a HUGE difference there.
We've been over this so many times on so many threads...
It sounds like the Ops friend is more concerned about comfort/ride than performance so I would recommend the A/S ZP.
Unsprung difference in weight has also been decreased. PS2 vs PS2 ZP gives you 10lbs advantage in unsprung weight for the whole car (2ea for front, 3ea for rear according to Tire Rack). If you can pick up that little unsprung weight in normal driving then you are probably too sensitive to be driving a Corvette. The AS/ZP is actually heavier than the PS2 ZP. (about 15lbs unsprung weight total).
I went from stock tires to Nitto Invos. I like that its much quieter now, and they feel as if they just grip better.
They have to use a stiffer sidewall so to not compress at the loss of air pressure and to be able to hold the vehicle up until the tire can be repaired.
I would suggest you do some more research as well then, it has beena known fact about runflats since they came out over a deceade ago.
Just as a side note and I didn't want to start a new thread. Just got invos on and love them so far.
What's the typical tire life people see with the invos under normal street driving?
Actually now that you ask, yes I did yesterday while my stock runflat was getting a nail pulled from it. The sidewall is stiffer than a non-run flat tire and is one of the main reasons the run flats ride rough.
So the stiff sidewalls are actually a misconception with 99% of the guys here believing it.
