Go Back   Corvette Forum > C6 Corvette, 2005 - 2013 > C6 Corvette General Discussion
Register Forgot Password?
Register Search Today's Posts Mark Forums Read FAQ Vendor Directory
Search
General C6 Corvette Discussion not covered in Tech Sponsored by
PFYC
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C7 Parts & Accessories
C6 Parts & Accessories
C5 Parts & Accessories
C4 Parts & Accessories
C3 Parts & Accessories
C2 Parts & Accessories
C1 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 04-19-2012, 08:31 PM   #1
txvettefan
CF Senior Member
Default Key fob programming
You might consider coping this post a word doc.
C6 Key Fob Programming Procedure:
IMPORTANT: This procedure is not available when the maximum number of 4 fobs
have been programmed. If 4 key fobs are programmed to this RCDLR and this method
is attempted, the driver information center (DIC) will display, MAX FOBS LEARNED
and the programming procedure will exit.
This procedure will add key fobs. Fobs will be numbered in sequence based on when
they are programmed; if 2 fobs are currently programmed to the RCDLR, a fob programmed
using this method will be numbered as Fob 3. This procedure requires that you have a
known good key fob, a replacement key fob, and the vehicle's mechanical key.
1. The vehicle must be off.
2. Open rear compartment
3. Place a known key fob within the interior of the vehicle.
4. At the rear of the vehicle, insert the vehicle key into the rear compartment lock cylinder,
located above the license plate and cycle the key 5 times within 5 seconds.
5. The DIC will display: READY FOR FOB X (X = fob 2, 3, or 4).
6. Place the replacement key fob in the glove box fob pocket with the buttons facing right.
7. A beep will occur and the DIC will display: READY FOR FOB X (X = fob 3 or 4) or
MAX FOBS LEARNED.
8. If programming additional key fobs, repeat steps 5 and 6, or press the OFF/ACC portion
of the ignition switch to exit programming mode.
9. Operate the active portion of each key fob in order to verify correct system operation.
Replacement battery CR2032
GOOD LUCK
txvettefan is offline   Reply With Quote
Old 04-19-2012, 08:45 PM   #2
ChevyDave
CF Senior Member
Support Corvetteforum!
ChevyDave's Avatar
or remember/save the C6 FAQ link...
http://forums.corvetteforum.com/c6-c...questions.html
about 1/3 way down under...
Key FOB Programming Instructions: http://forums.corvetteforum.com/c6-c...tructions.html
Last edited by ChevyDave; 04-19-2012 at 08:47 PM. Reason: corrected to 1/3 way down (fat fingers)
ChevyDave is offline   Reply With Quote
Old 02-12-2013, 06:21 PM   #3
Devilish34
CF Senior Member
Devilish34's Avatar
MAX FOBS LEARNED.
GOOD LUCK
I'm trying to add a fob but cannot get the car to beep or DIC to turn on after I turn the key the 5 times.. Any help would be appreciated
Devilish34 is offline   Reply With Quote
Old 02-12-2013, 06:32 PM   #4
ChevyDave
CF Senior Member
ChevyDave's Avatar
i've read that it counts 5 in 5 seconds, but you can turn it HARD as many times as you need to make the 5 count. maybe up to 20+ times before it finds 5 good ones.
you are positive that a good fob is located in the car when it normally would start the car?
one person said this is no the only way they could get the 5 to count...
http://forums.corvetteforum.com/1570351932-post19.html
added Elmers programming method.. http://www.ls2.com/boggs/c6/C6%20Fob%20Programming.pdf
fyi... i see your from PA so this most likely doesnt apply, but.. I have read that Canadian version cars can only have a fob programmed at a dealership. just a fyi
Old 02-12-2013, 07:13 PM   #5
Devilish34
CF Senior Member
Devilish34's Avatar
I got it lol Thanks for the quick reply.. My licence plate frame was keeping my fat fingers from making the full turn required to work.. I took the plate and frame of and in the first try it worked
Old 02-12-2013, 07:15 PM   #6
ChevyDave
CF Senior Member
ChevyDave's Avatar
Quote:
awesome!!!!!!!!!!!!!!!!!
Old 02-13-2013, 12:42 AM   #7
CO Lightfoot
CF Senior Member
CO Lightfoot's Avatar
From another thread:
Quote:
Originally Posted by RicK T View Post
First, you are aware there is a "short" programming procedure to add another FOB, which in most cases would be #3, which means the new one won't work with the driver memory settings. Only #1 and #2 can work the memory settings.
So, if you just want to "add" FOB #3 (or #4, the max is 4) then you use the short procedure.
To make a new #1 (or #2) FOB, with access to the memory settings, then you have to use the "long" programming procedure, which is lengthy. Doing the "long" procedure means you erase all existing FOB's from memory and start over. The first FOB you program will be #1, the second will be #2 for memory settings purposes.
The procedures in the manual seem to work only sometimes.
Here is a verified and tested procedure, long and short, that will work if you follow exactly.
OR you could go back to the dealer and have them do it, probably for a fee. Good luck.
CO Lightfoot is offline   Reply With Quote
Old 02-13-2013, 06:43 AM   #8
FortMorganAl
CF Senior Member
FortMorganAl's Avatar
Location: Currently somewhere in IL,IN,KY,TN,MO,AR,MS,AL, or FL
This procedure will add key fobs. Fobs will be numbered in sequence based on when they are programmed; if 2 fobs are currently programmed to the RCDLR, a fob programmed using this method will be numbered as Fob 3. ...
This means that you should NEVER have to do this or any other FOB programming procedure unless you are adding new FOBs to the system. Each FOB contains only a unique identifying ID. It is the car that remembers which FOBs are "legal". You program the car to accept a new ID as valid. The car NEVER forgets an ID unless you do the long procedure instead of this short procedure or start replacing RDCL components in the car. Removing batteries from the FOBs or car do not cause the car to forget.
If you are having problems with your FOBs you NEVER need to reprogram the car unless you give up and buy a new FOB.
FortMorganAl is offline   Reply With Quote
Old 02-13-2013, 06:50 AM   #9
C7Joy
CF Senior Member
C7Joy's Avatar
Filing this away just in case! Thanks for sharing.
C7Joy is offline   Reply With Quote
Reload this Page Key fob programming
Tags
c5, c6, corvette, fob, fobs, key, program, programming
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Programming new FOB bdeis61159 C6 Corvette General Discussion 2 07-22-2014 08:16 PM
C6 Comprehensive Fob Programming Instructions cclive C6 Corvette General Discussion 375 07-03-2014 05:39 PM
Another fob programming FAIL!! zildjianz06 C6 Tech/Performance 58 04-02-2014 07:43 AM
How to Reprogram or Add a Fob Baxter's Dad C6 Corvette General Discussion 0 08-28-2013 07:04 PM
Fob programming #1 short or long method? greenbeauty C6 Tech/Performance 5 05-15-2013 12:21 PM
Emails & Password Backup
Search Engine Friendly URLs by vBSEO 3.5.2
