Technical/Wheels Questions
Old 08-23-2015, 02:24 PM
mdwsr2003
mdwsr2003's Avatar
Location: Metro Atlanta (by way of L.A.) Ga (Army Strong Retired)
Default Technical/Wheels Questions
I replaced my Cray Scorpions 18/19 setup with runflats with
Cray Brickyard 19/20 setup with non runflats
1) Now my Traction Control Active indicator continues to pop up where my odometer reading is
Ive always had my traction control on and have never seen this
2) Now I can feel the rear end feeling like it wants to get away from me
Is there something that I need to reset that I don't know about?
any help would be greatly appreciated
Old 08-23-2015, 03:06 PM
Entaille
Entaille's Avatar
what is the new tire make and model, and what size in front and rear?
I suspect you strayed too far from the original O/D sizing and your ratios are off and your handling/engine drag systems may not be happy.
Old 08-23-2015, 03:26 PM
mdwsr2003
mdwsr2003's Avatar
Default Vredestein 245/35/19 ZR fronts and 295/25/20 ZR Rears
Old 08-23-2015, 03:44 PM
Entaille
Entaille's Avatar
what width are your wheels? your tire sizes are causing the issue, at least for TCS message.
Old 08-23-2015, 03:45 PM
Kent1999
Kent1999's Avatar
Received 1,651 Likes on 825 Posts
Width of the tire, and wheel diameter don't matter but overall *tire diameter* (and its ratio F/R) is key for TCS/ABS-- you need to maintain about a 1" taller rear tire diameter than front diameter. If you don't, you'll get exactly the symptoms you describe.
I don't have my tire calculator handy, but from the sound of the sizes quoted, it sounds like the front/rear tire diameters are too close, and do not maintain the +1" rear diameter bias required.
You might also check to make sure that one of the speed sensors on the wheel hubs was not accidentally disconnected during the tire/wheel changeover. (Less likely, but that's the next thing I'd check if the tire sizes are ok)
Old 08-23-2015, 03:52 PM
mdwsr2003
mdwsr2003's Avatar
Originally Posted by Kent1999
Width of the tire, and wheel diameter don't matter but overall *tire diameter* is key. You need to maintain about a 1" taller rear tire diameter than front diameter. If you don't, you'll get exactly the symptoms you describe.
Old 08-23-2015, 04:10 PM
Kent1999
Kent1999's Avatar
Yeah, those are almost exactly the same height (25.75"F, 25.81" R).
You need to go up to a larger diameter rear tire (295/30-20?).
*Or* a smaller front (245/30-19)
Either way would give you the +1" rear figure you need. I'd recommend increasing the rear diameter, as that would keep you close to the OEM diameters.
Old 08-23-2015, 04:29 PM
mdwsr2003
mdwsr2003's Avatar
Thank you for the feedback
Old 08-23-2015, 04:46 PM
mdwsr2003
mdwsr2003's Avatar
looked at my paperwork and the sizes above you said are the exact sizes that I ordered, they put the WRONG SIZE rears on ( at least not the size I ordered 295/30ZR20)
Now I just got them yesterday and drove it straight home and parked it. They are a pretty reputable company here in Atlanta (I wont say their name YET) so hopefully they will make this right.
Old 08-23-2015, 04:47 PM
Entaille
Entaille's Avatar
I asked what width your wheels were earlier so I could suggest a good combo of tire sizes
I run 255/35/19 and 305/30/20 and it keeps everything happy. this is on 19x9 and 20x11 wheels.
oh cool - sounds like it was just a mistake from the shop, they will fix ya up I imagine!
Old 08-23-2015, 04:50 PM
mdwsr2003
mdwsr2003's Avatar
I think Kent1999 above may have found my problem, see his above reply, but thank you very much for responding.
Old 08-25-2015, 07:10 PM
mdwsr2003
mdwsr2003's Avatar
Kent1999 you were exactly on the money on this one
Called em Monday morning, told em about the tire issue, and as I said they have an outstanding reputation here in Atlanta. There were no questions, no blame shifting just Sorry we screwed up, bring your car back and we will fix it immediately. Picked it up and although I just got the tires Saturday and the rears were the only issue, They put 4 brand new upgraded tires on it. So thank you Butler Tires, way to take care of your customers. Not to mention the Cray Brickyards look awesome to me. No pics yet. Came matte black and had empainted Shiny Gloss Black
Old 08-25-2015, 10:26 PM
cartop2
cartop2's Avatar
Great that your tire company did the right thing, and nice move on your part not trashing them while figuring out what went wrong and getting it fixed. I would like to see the wheels and tires on your car if you can post a photo.
Old 08-26-2015, 06:12 PM
mdwsr2003
mdwsr2003's Avatar
Not the greatest quality pics (IPhone) but here are a few
https://www.corvetteforum.com/forums...27132440627132
Old 08-26-2015, 09:22 PM
Not So Fast
Not So Fast's Avatar
So we assume that the problem originally asked has been remedied by the tire sizes correct???? Good to know
NSF
Old 08-27-2015, 06:27 AM
mdwsr2003
mdwsr2003's Avatar
NSF
oh yes indeed, problem was instantly gone thanks for the tips fellas
man I purchased this car brand spanking new in December 2006 right off the showroom floor in Honolulu Hawaii and I must say 57,000 miles later and I still love it its an 07
Old 08-27-2015, 07:24 AM
05 Wreck
05 Wreck's Avatar
Default Sticky?
NSF
Great info for when I use my TSW Nurburgrings! Suggest moderators make this a sticky or post in FAQ. Useful.
Old 08-27-2015, 08:05 AM
Tonylmiller
Tonylmiller's Avatar
Related question:
I had a message come up in the DIC the other day that said something like "CALIBRATING TRACTION CONTROL". I don't recall the exact words.
I checked my tire pressure and only one of my rear tires was about two or three psi low.
Has anyone else seen this message? It seems that the system can compensate for a small difference in rolling diameter of the tires from side to side, but not front to rear.
Old 08-29-2015, 08:23 PM
cartop2
cartop2's Avatar
Thanks for posting the photos. The wheels and tires look great on your Vette.
Hawaii? Are Corvettes allowed in Hawaii?
Just kidding. If single, I can't imagine what it would be like driving an attention getter like that around on an island filled with tourists. All the stopping to let them look at the car would detract from the driving. Oops, I think that I have wandered off topic.
To Technical/Wheels Questions
Quick Reply: Technical/Wheels Questions
