Installed HID Fog Lights Pics and How to.
Old 04-10-2012, 09:30 AM
petermj
petermj's Avatar
Is the current draw less or more than with OEM bulbs?
Old 04-10-2012, 09:49 AM
McPeds
McPeds's Avatar
I installed these and have noticed a jiggle on small bumps with the ballasts on top of the housing. They are too heavy to be placed on top. Don't know about heat. I will be moving them when I go back in to swap out the headlights and DRL.
Old 04-12-2012, 03:29 PM
0corvettemods1
Former Vendor
corvettemods1's Avatar
St. Jude Donor '12-'13
Less at operating temp!
Old 04-14-2012, 08:29 AM
JKbride
Support Corvetteforum!
JKbride's Avatar
W. GA Events Coordinator
St. Jude Donor '12-'13-'14-'15
Originally Posted by Polar Jet
Has anyone had a problem with mounting the ballasts on top of the housings? I seem to recall when researching it that it was considered a bad idea due to heat and the weight of the ballast causing the assembly to jiggle.
I drove mine at night for the first time yesterday and did not notice any movement from the fog light housings while going over bumps and the like.
All I can think of is that the wires coming out of the ballast are not secured in a way that takes the stress and weight off the ballast, which in turn may cause the housing to move when you hit bumps.
In my case not an issue that I observed.
Old 04-14-2012, 11:45 AM
0corvettemods1
Former Vendor
It been installed that way since I can remember and have never heard of or seen any type of movement due to ballast placement on the housings
Old 04-14-2012, 03:35 PM
LS WON
LS WON's Avatar
So the ballast is the weak link in the chain and if there are problems down the line this is the item to look at first?
Old 04-14-2012, 03:43 PM
C7-Beast
C7-Beast's Avatar
My kit arrived today. Quality looks excellent. Neal shipped super fast. The ballast does not seam very heavy to me. Possibly if the weight of the cable was pulling down I could see it maybe shaking the light. I'm going to install on top of the fog light housing. I plan on installing next weekend. My install should be cake as the bumper is currently off the car since it was just painted. It came back today but giving it some time to cure before re installing.
EVRose
EVRose's Avatar
I've had my ballasts stuck on top of the housing for a couple months now. I use the lights a lot and dont have any bouncing at all.
Old 04-14-2012, 03:48 PM
0corvettemods1
Former Vendor
Old 04-14-2012, 03:54 PM
LS WON
LS WON's Avatar
Ballasts are suppose to be slim and lightweight actually.
Old 04-14-2012, 05:01 PM
C7-Beast
C7-Beast's Avatar
Was just surprised to read someone saying they were too heavy for the fog light enclosure. Not a ballast expert, but these things are so small and light, I can't see them causing an issue.
Old 04-14-2012, 06:42 PM
flashburn
flashburn's Avatar
Thanks for the write-up. Going to do this in a few weeks.
Old 04-18-2012, 12:31 AM
  #33
0corvettemods1
Former Vendor
Old 04-18-2012, 09:28 AM
  #34
McPeds
McPeds's Avatar
Noticed the fog lights jiggle on bumps a lot the last few nights. Will have to go in a check the whole assembly. But a jiggle is not an unheard of problem. I read another older post recommending not mounting the ballast on top due to jiggle and one complaint that the plastic clips holding the light whole assembly break easily. On person on the forum reinforced the whole light assembly and that fixed the jiggle. Of course I could just have really big potholes. Great lights tho!
Old 04-18-2012, 07:54 PM
  #35
jcdreamer
jcdreamer's Avatar
Please update us when you finish as I'm very interested in doing the same mod.
Old 04-18-2012, 09:08 PM
  #36
07atomic
07atomic's Avatar
I mounted the ballast in the frame rail just beside the fog light it fit perfect drilled 2 small holes held in with small self taping screws. Seemed like the best place I found did not want the extra weight on the plastic housing.
Old 04-18-2012, 10:17 PM
  #37
LS WON
LS WON's Avatar
To Installed HID Fog Lights Pics and How to.
Old 04-24-2012, 01:32 AM
  #38
0corvettemods1
Former Vendor
Old 04-24-2012, 01:35 AM
  #39
brooklync5
brooklync5's Avatar
very helpful write up for those who haven't done this before... I'm sure you will be getting many thanks.... this was my first mod..
Old 04-24-2012, 10:43 AM
  #40
LS WON
LS WON's Avatar
Quick Reply: Installed HID Fog Lights Pics and How to.
