Go Back   Corvette Forum > C6 Corvette, 2005 - 2013 > C6 Corvette General Discussion
Register Forgot Password?
Register Albums Search Today's Posts Mark Forums Read FAQ
Search
General C6 Corvette Discussion not covered in Tech Sponsored by
PFYC
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 04-05-2012, 05:24 PM   #1
ryanparmstrong
Junior Member
Default C6 Seat Problems
Howdy forum members,
Just graduated Texas A&M and bought my first vette (2005 Blacked out 3LT with an LS3 swap).
I am fixing a couple of minor issues on the vehicle and am down to the drivers side seat. The memory module works, heating system works, and the lumbar system is functioning properly. However, it seems that the power seat adjuster isn't working.
All the fuses seem to be fine, so at this point all it can be is the seat motor or the seat controller module? or at least that is my best guess.
Any tips or thoughts?
ryanparmstrong is offline   Reply With Quote
Old 04-05-2012, 05:59 PM   #2
ChevyDave
CF Senior Member
Support Corvetteforum!
ChevyDave's Avatar
Dang, same problem as this?
http://forums.corvetteforum.com/c6-c...t-problem.html
ChevyDave is offline   Reply With Quote
Old 04-05-2012, 06:15 PM   #3
VET4LES
CF Senior Member
VET4LES's Avatar
Some C6's have connector problems. I know I did. The first thing you need to do is check the connectors under the seat. The picture below shows mine that I zip tied together. I pulled the tie very tight. This could solve your problem.
Click the image to open in full size.
VET4LES is offline   Reply With Quote
Old 04-05-2012, 07:53 PM   #4
ryanparmstrong
Junior Member
I verified that the fuse is good and it is. Unfortunately my buddy is borrowing my socket set so I can't take the seat out till the weekend.
Does anyone know what kind of voltage levels that 6 pin connector puts out? Id guess 5V or 12V, but if anyone knows for sure that would be great! I am going to try and send the motor some voltage and see if it moves the seat to verify that its the controller and not the motor.
Thanks ChevyDave and VET4LES for the info!
Old 04-05-2012, 07:59 PM   #5
VET4LES
CF Senior Member
VET4LES's Avatar
I didn't take my seat out. I moved it back and up. I know you can't move it but try sticking your hand under it and pulling the wires out. If you can't do that try using a yard stick or something similar and move them around. That might be enough to get it to move.
Old 04-05-2012, 09:00 PM   #6
ryanparmstrong
Junior Member
Well, its the controller I'm almost 100% sure. The connector on the switch wasn't plugged in, and after I plugged it in and tried to start the car it seemed to short the car to ground and now my battery is dead. Its been a wonderful day.
Old 04-06-2012, 12:15 AM   #7
All2Easy
CF Senior Member
All2Easy's Avatar
Congrats on the car, and good luck with getting her sorted out!
Gig Em!
Thomas, class of '93
All2Easy is offline   Reply With Quote
Old 04-07-2012, 10:01 PM   #8
ryanparmstrong
Junior Member
Thanks All2Easy! It's been a rough road, but luckily Im decent at troubleshooting this stuff. Guess that engineering degree paid off
Gig em!
Reload this Page C6 Seat Problems
Tags
2005, c6, corvette, power, problems, seat
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Emails & Password Backup
Search Engine Friendly URLs by vBSEO 3.5.2
