Recommended Tire pressure?
Old 03-16-2012, 03:02 PM
  #41
Gearhead Jim
Support Corvetteforum!
Gearhead Jim's Avatar
Received 2,051 Likes on 1,362 Posts
St. Jude Donor '13
Originally Posted by LS WON
I don't think so as everyone knows it when tires are cold that is when to check them.
California must have different "everyones" than Illinois.
Good for you.
I can only count one or two times when a shop in Illinois has tried to mention or compensate for the difference.
Gearhead Jim is offline
Old 03-16-2012, 03:03 PM
  #42
SnakeBT6
SnakeBT6's Avatar
Whoops, duplicate post.
SnakeBT6 is offline
Old 03-16-2012, 03:05 PM
  #43
SnakeBT6
SnakeBT6's Avatar
Mine are at 28 cold and as they warm up im right at 30.
What I did notice though is I have less traction when the rears are over 32..
The dealer inflated to 32 at my last oil change. When the car got warm they were up around 35 and noticed a difference in both firmness of the ride and less grip in the rear under hard accelleration. So I felt anyway and changed them back to what they were.
SnakeBT6 is offline
Old 03-16-2012, 03:10 PM
  #44
cadguymark
cadguymark's Avatar
exactly how cold is cold?
on the few occasions I have been able to drive my car in winter the tire pressure has been close to the tripping point for low pressure warning, the outside temp was about 10F, I think it may have even been at 0 or possibly a little below, driving the car for awhile brings the pressure up to 30
on the other hand, right now the tire is at 30psi cold, but then it is 75 in March right now (normally we'd be lucky to be above freezing)
cadguymark is offline
Old 03-16-2012, 03:17 PM
  #45
LS WON
LS WON's Avatar
Car wants to jump on bumps.
LS WON is offline
Old 03-16-2012, 04:09 PM
  #46
X25
Sr.Random input generator
X25's Avatar
Received 1,465 Likes on 1,022 Posts
Originally Posted by marc8090
I believe the over pressure or under pressure message occurs at 20% difference from 30 psi. At 35 cold you're only one pound away from getting a high pressure message, which will certainly happen once the tires warm up.
I don't think this is true. I used 38 PSI as a starting pressure before, testing tire / pressure combinations at the track, and I never had a warning due to tire pressure.
From the service manual:
When the TPM system detects pressure above 42 psi the HIGH TIRE PRESSURE warning message is displayed
When the TPM system detects pressure between 5 and 25 psi the LOW TIRE PRESSURE warning message is displayed
When the TPM system detects pressure below 5 psi the FLAT TIRE warning message is displayed.
X25 is offline
Old 03-16-2012, 05:36 PM
  #47
LS WON
LS WON's Avatar
Up to 40 psi we got warnings
LS WON is offline
Old 03-16-2012, 05:49 PM
  #48
hawkgfr
hawkgfr's Avatar
Received 1,212 Likes on 824 Posts
32 front and 30 rear for me...Seems to get the best wear for me.
hawkgfr is offline
Old 03-16-2012, 05:54 PM
  #49
LS WON
LS WON's Avatar
It's been 30/30 for me.
LS WON is offline
Old 03-16-2012, 10:04 PM
  #50
carjo
carjo's Avatar
Follow the direction on the door.
Chevy has spoken....
carjo is offline
Old 03-16-2012, 10:24 PM
  #51
LS WON
LS WON's Avatar
Always have but wonder why both Tire shop and alignment person in another shop both concur with the 35 psi?
LS WON is offline
Old 03-16-2012, 11:01 PM
  #52
Nice Ride
Nice Ride's Avatar
31 cold all year all around.
Nice Ride is offline
Old 07-02-2012, 03:54 PM
  #53
Thunder22
Thunder22's Avatar
Received 2,312 Likes on 1,457 Posts
For those running 30psi, is that regardless of tire brand? I just replaced the GY's with Michelin PS2 ZP's and the tire shop pumped 'em up to 35. Still run 30psi?
Thunder22 is offline
Old 07-02-2012, 04:04 PM
  #54
redrckt97
redrckt97's Avatar
Originally Posted by Gary '09 C6
I try to keep it at 32 psi front and 30 psi rear (cold).
guess I'm just different !
same here- 32 front / 30 rear in the hope of delaying the normal front tire wear. Note they will all gain around 5 psi when hot so 35 cold is too much (imho).
redrckt97 is offline
Old 07-02-2012, 04:48 PM
  #55
Vette_DD
Vette_DD's Avatar
Received 1,276 Likes on 935 Posts
GM doesn't tell you that it depends on the tire brand.
And please, don't retrieve old threads. Start a new one.
http://forums.corvetteforum.com/foru...s-or-more.html
Vette_DD is offline
Quick Reply: Recommended Tire pressure?
