Don't leave the key fob in the car for a week
My buddy could not find the fob under the seat. It was under power seat motor. The fob is constantly "talking" to car and the car is constantly answering. After one week, both batteries were dead. AAA was called to open door (rear key could not be found). Harness bar stopped us from crawling into back. Car battery was charged under the hood. This was the perfect storm for not keeping track of keys.
The only other way is if something was stuck in the fob button, causing it to be constantly depressed.
NO! Didn't happen. Fob doesn't "talk" to the car unless you press a button on the fob, try to open the car door while you have the fob near the door, or try to push the button to open the rear hatch while the fob is near the hatch.
Unless it was jammed under the seat such that one of the buttons was being held down the whole time, it did not happen the way you think. It does not matter where a fob is kept, the system does not work that way. Jim is correct.
Moderator
Received 3,592 Likes
Received 2,186 Likes
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13-'14-'15- '16-'17-‘18-‘19-'20-'21
NCM Lifetime Member
How does one go an entire week and not realize a fob is MIA ?
ok...
So a car has 2 FOB's and a KEY... if you lose them, it is like any other car... deal with it... PS "IF" you open the hatch, no need to crawl in.. just pull the remote wire to open the door, on the left side in the hatch...
The fobs should be fine, as mentioned, they don't use up any more battery power regardless of where they're located.
Although the OP indicated "both batteries were dead", I don't think either fob battery died - the dead car battery would prevent either fob from "working" (they probably both "work", but thedead car battery prevents anything from "working").
To the OP - gotta keep the key handy, so you can get into the hatch, and open the doors. But I believe the car should always be charged or jumped from the front... Could be wrong, but I think that's the rule with the Z06.
Sr.Random input generator
I'm getting a different interpretation of what happened. With the fob in the car, wouldn't the car constantly be "waking up" trying to determine if the car should be started? I would expect that could kill the car battery in a week.
If they were constantly trying to communicate with each other then the batteries would go dead no matter where they were located. The car battery went dead in a week because abused/old batteries go dead in a week.
The rest of your comments are correct, IMHO.
NCM Lifetime Member
No. The car ands FOB only try to communicate when a button is pushed. Opening a door, closing a door, trying to start the engine, etc. One of the communications is to determine if the FOB is inside or outside the car. That is done by having multiple receivers in the car. But it is only done when trying to determine if you have removed a FOB from the car before it auto locks. That is initiated by opening and closing the door. If the door isn't opening/closing (and no other buttons are be3ing pressed) then the car couldn't care less where the FOB is so it doesn't communicate to find out.
