Motor Oil
Motor Oil
What is the best motor oil to use in a 2011 vette. This is the first oil change that will be done. Trying to determine what everyone recommends.
Thanks in advance...
Moderator
Received 3,594 Likes
There are about a thousand of these threads. There are those that support Royal Purple, those that like Amsoil. There isn't a good reason to switch from Mobile One, but any oil that meets GM Spec GM4718M will be fine.
Your vehicle’s engine requires a special oil meeting
GM Standard GM4718M. Oils meeting this
standard may be identified as synthetic. However,
not all synthetic oils will meet this GM standard.
The Consigliere
Received 5,458 Likes
If your car is a street driven vette only, then original fill Mobil 1, 5/30 is what you should use.
Received 2,485 Likes
St. Jude Donor '15
"In honor of jpee"
I'm just clicking to increase my post count and learn what oil I should use.
Received 2,899 Likes
Goon Squad King of Battle
St. Jude Donor '08-'09-'10-'11-'12-'13x3- '14-'15-'16-'17-'18-'19-'20-'21-'22-'23
actually, you could put darn'd near anything in your corvette and the car "just wouldn't give a crap"...
St. Jude Donor '15
"In honor of jpee"
