Clutch Fluid???
Clutch Fluid???
After reading Carl3989's post on the need to change fluid on a regular basis I thought I should check mine. Pretty black and just two years, thanks carl3989. So I check the manual regarding type of fluid and head off to the parts store. No one has heard of "Super DOT4 brake fluid". One store had DOT4 but all the other had a DOT3-4 multi grade. I wound up buying Valvoline DOT3-4 synthetic. Can any one tell me if this is the right stuff before I put it in and screw something up?Thanks
I did exactly the same thing on my 08. After seeing the first post I checked my reservoir, nothing but black sticky gunk on the bottom. I was surprised that the clutch still worked.
I bought the Valvoline Dot 3-4 synthetic too. I went through the whole 32 oz. bottle before
it was clean. I bought another one and will change it at least once a year. The clutch does
seem to engage sooner now than it did before.
You're welcome Diver.
I just buy a small bottle of the Prestone (black bottle, not yellow) and then change the fluid every week until the bottle is gone. This allows for circulation of the new fluid without needless wear on the system. I drive the car as a DD. A bottle will do at least 4 changes.
I Rangered my fluid yesterday and I can say with complete certainty that you will need to drive the car in between swaps to get it clean. Simply pumping the clutch does not allow the fluid to cycle through the hydraulic system enough to get all the gunk in suspension, no matter how many times you do it. It works for about the first half dozen swaps but you're not going to get anything else out of the hydraulics after that without actual operation of the system.
I got the fluid nice and yellow, drove 2 miles.....black as night again. I'm going to use a method similar to cclive's. Swap with 2-3 sets of replacement/clutch actuation, followed by a brief drive on the clean fluid to have it mix adequately with the remainder of the contaminated fluid. I'll rinse and repeat every few days until it's actually clean after the drive.
I like the Castrol Dot4 they sell at autozone. Its not at advance for some reason. The reason I like it is its almost clear, not amber, so I can judge how much its gunking up easier.
I Rangered my fluid yesterday and I can say with complete certainty that you will need to drive the car in between swaps to get it clean. Simply pumping the clutch does not allow the fluid to cycle through the hydraulic system enough to get all the gunk in suspension, no matter how many times you do it. It works for about the first half dozen swaps but you're not going to get anything else out of the hydraulics after that without actual operation of the system. I got the fluid nice and yellow, drove 2 miles.....black as night again. I'm going to use a method similar to cclive's. Swap with 2-3 sets of replacement/clutch actuation, followed by a brief drive on the clean fluid to have it mix adequately with the remainder of the contaminated fluid. I'll rinse and repeat every few days until it's actually clean after the drive.
Retired & lovin' it!
Both Prestone & Napa have a Dot 4 fluid which is what you want to use. Also, in the Auto section at most WalMarts, you can get a fat bodied syringe (brand name 'MixMizer') that works great for drawing the old fluid out of the reservoir. I've been using the 'pump the pedal' routine to circulate the fluid & haven't had any problems.
EDIT: the one that Dave S mentions above.
