Stock Shifter O-Ring
The o-ring on my MN6 shifter broke into multiple pieces, some of which were lost, so I am unable to use it to match up to find a replacement. Does anyone happen to know either where I can purchase a replacement, or what the specific size is?
The lack of an o-ring is causing the metal piece at the top of the boot vibrate and fall down, and the noise is driving me batty.
TIA
TIA
Race Car Tech
TIA
TIA
If you want an O-ring, then go to your local parts store and ask for a 1" diameter O-Ring. That will give it a snug fit.
Good luck
Since the O-Ring is hidden, a small sized zip tie can also be used instead of the O-Ring. Tuck the small zip tie joint up next to the seam on the boot and you'll never notice it.
Good luck
Good luck
I'll be making a trip to my local Ace Hardware this weekend to preserve my sanity.
