C6 Don't Like speed limit signs!
Old 01-02-2017, 04:21 PM
Giamanut
Giamanut's Avatar
Default C6 Don't Like speed limit signs!
So I have a 07 monty Red coupe and oops tagged a curb and flatten a 35 mph sign. Ah embarrassing thing to happen when your not fooling around!
Now there is a question in all this, the car went to the local GM dealer for repairs IE front bumper and a few smaller items and one right front rim.
Repairs are done new rim and tire installed and alignment done.
Test drive by alignment shop and steering wheel shake right off the bat
can't even drive it!
So it is cold up here in Utah and I should not of had the car out anyways but I do have concerns about this shop they out soured the tire mount and balance But I expect the rim would have to be bent to induce the wobble at such low speed.
suppose to be a new rim.
Also after murdering the speed limit sign, I drug my bumper down the road about a block and turned on to a side street with no shake at all.Ah blinked for a second but that is all.
Damage to rim was 1/4 inch long nick and about the same length cut in the tire.
So what could cause this. the tech said the front end was tight when he aligned it.
Old 01-02-2017, 05:43 PM
Red Devil Z51
Support Corvetteforum!
Red Devil Z51's Avatar
some times the wheel fits very tight on the hub. If they don't get it seated right it will wobble and shake pretty bad. Take off any wheels they took off and reseat em. This happened to me when they took it apart to paint calipers and wheel barrels. Was a very easy fix.
Old 01-02-2017, 07:23 PM
Giamanut
Giamanut's Avatar
Thanks I feel in definitely that wheel I will let them know first thing in the morning
Old 01-02-2017, 07:49 PM
buckmeister2
buckmeister2's Avatar
Received 1,206 Likes on 824 Posts
It's just me, but I wouldn't try to figure it out. I would just take it to the dealer and tell them to fix it. Of course, I wouldn't have taken it to a dealer in the first place, but that is just me.
Old 01-02-2017, 10:16 PM
Giamanut
Giamanut's Avatar
It's at the dealer been they put the new rim on perfect smooth too severe
Steering wheel wobble with the change of the rim. don't know if it is an after market rim or not. but it was solid until they changed the rim.
Not taking it back from the dealer until it is right but I still want to know.
Old 01-02-2017, 10:26 PM
buckmeister2
I'm sorry...I am really trying to figure out your reply. I thought you had the car back, and were seeking advice. I thought that is where your first post left off.
Hope the dealer fixes it....it is their issue to fix.
Old 01-03-2017, 08:08 AM
ben dover
ben dover's Avatar
Location: When all is said and done... there is a hell of a lot more said than done. Riverside,Texas
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18-'19-'20-'21-'22-'23-'24
Did it bend the rim or scratch the rim? Could there be suspension damage?
Old 01-03-2017, 08:12 AM
Corvette_Ed
Corvette_Ed's Avatar
Received 2,843 Likes on 1,801 Posts
Translation?
So solly; I don't speak Engrish velly well.
Old 01-03-2017, 09:00 AM
dryadsdad
dryadsdad's Avatar
Find a shop to do a road force balance. You may have a bad tire.
Old 01-03-2017, 09:36 AM
FortMorganAl
FortMorganAl's Avatar
Location: Currently somewhere in IL,IN,KY,TN,MO,AR,MS,AL, or FL
Is this a rhetorical question? The work was done by a dealer! Answer seems obvious to me. Dealers specialize in selling cars, not body work.
Old 01-03-2017, 02:26 PM
Giamanut
Giamanut's Avatar
Small scratch and car was smooth afterwards!
Old 01-03-2017, 02:31 PM
Giamanut
Giamanut's Avatar
True but the dealer has a body shop! and they where only a few blocks away.
They actually sent it to a Nissan shop for the alignment because they could not get it on the rack and they are a GM dealer!
I went and talked to the tech at the Nissan dealership so I hope that helps. Just told him the car was smooth, they put the new wheel on and it wobbles so yea it is the wheel and most likely the installation of the wheel!
Old 01-04-2017, 10:01 AM
FortMorganAl
Which is why you go to a tire and suspension place for tires and suspension work and not a dealer. If a dealer screws up working on a car, they still survive because they make enough selling cars to not need the repair business. A tire shop that screws up suspension work is risking bankruptcy. And a tech that does 10 alignments a day probably does them better than a tech that does 10 a month.
Old 01-04-2017, 11:54 AM
Itshakes
Itshakes's Avatar
Old 01-04-2017, 06:21 PM
buckmeister2
Maybe more accurately, G,it is not actually the dealers body shop. More likely, they partner with a place that gets all their work. Now, if the body shop has the dealer's name on the front, I am wrong, but very few dealer's have their own body shop any more.
I sure hope things are working out for you on this little nightmare.
To C6 Don't Like speed limit signs!
Quick Reply: C6 Don't Like speed limit signs!
