UPDATE: Shoe Scuffs on Rocker Pannel Door Jam Plastic Results.
Old 02-10-2012, 08:40 PM
dougerls3
dougerls3's Avatar
Default UPDATE: Shoe Scuffs on Rocker Pannel Door Jam Plastic Results.
Hello All,
Well, I tested about a dozon things recommended on CF to take the black shoe scuffs off the rocker pannels door jams when getting in. 2008 LS3, Red with black and tan interior. Again, for those who did not read my first post, I did not put them there as the first owner did. Out of all the suggestions the only one that really worked was the regular Magic Eraser. It was not easy. I used warm soapy water and the eraser. It took many times of rubbing, maybe 300 or 400 strokes with some force to slowly remove them little by little. No damage at all. Looks like they were never really there at all now. Recommended by me for what that is worth.
: salute:
Thanks,
Doug
Old 02-10-2012, 08:48 PM
george vee
Support Corvetteforum!
george vee's Avatar
Received 1,073 Likes on 532 Posts
2015 C7 of the Year Finalist
Thanks will give it a try.
Did you do it wet or dry?
Old 02-10-2012, 08:59 PM
Vette_DD
Vette_DD's Avatar
Received 1,276 Likes on 935 Posts
Mr. Clean Magic Eraser - don't need any soap with it. Usually comes multiple eraser-sized pads in a box. Get'em at Wally World in the auto detailing aisle, or in grocery stores in the detergent aisle, especially Krogers.
Wet an eraser, wring out the excess water, 2 or 3 light swipes, slightly abrasive.
Old 02-10-2012, 09:05 PM
dougerls3
dougerls3's Avatar
Wet for sure, with a little bit of warm dish washing soap in a bowl.
Doug
Old 02-10-2012, 09:09 PM
dougerls3
dougerls3's Avatar
For me, wet and warm water with soap lowered the friction when rubbing. Did not try dry as I was worried about scratching. I would not do it dry. FWIW...
Doug
Old 02-10-2012, 09:15 PM
VET4LES
VET4LES's Avatar
I learned about the eraser on the forum in 2005 and have used it since. Great product.
Old 02-10-2012, 09:24 PM
dougerls3
dougerls3's Avatar
Agree. No damage and works well. Did you use it dry or wet?
Doug
Old 02-10-2012, 10:15 PM
Grzldvt1
Grzldvt1's Avatar
In my detail shop we use them all the time for this very purpose. You always want it to be wet when you rub it back and forth.
Old 02-10-2012, 10:26 PM
Gene Culley
Premium Supporting Vendor
Gene Culley's Avatar
I wonder if it may be just easier/cost efficient for you guys to replace them?
__________________
Phone: 484-334-8833
Owner of CULTRAG Performance
Shop Our Factory GM Parts Website
Old 02-11-2012, 12:00 AM
Metal Skull
Metal Skull's Avatar
That's what she said!
Old 02-11-2012, 10:17 AM
dougerls3
dougerls3's Avatar
15 min. worth of work and $2.25 is not too much trouble. Going to the dealer, paying for a new one is.
Doug
Old 02-11-2012, 11:07 AM
TheLoneRanger
TheLoneRanger's Avatar
Do not use the Magic Eraser product dry! It is made of melamine and is very abrasive when used dry. With enough force and enough time you will take the paint off. Wet, they are perfect. I used one on one of my tail light lens to get magic marker off of it. I also used it to remove the residue from where the dealer tag was glued to my back bumper.
Bill
Old 02-11-2012, 11:28 AM
Bootlegger
Bootlegger's Avatar
Magic Eraser believer here as well
Old 02-11-2012, 11:35 AM
Street Rat
Street Rat's Avatar
Soft Scrub here. Works fast and easily.
Old 02-11-2012, 11:39 AM
Keppler
Keppler's Avatar
Magic Eraser works good.
On my black interior, I placed 2" wide black vinyl tape on the door jam trim piece (drivers side only) to protect the surface.
Old 02-11-2012, 11:45 AM
Otherslost
Otherslost's Avatar
The magic eraser worked great getting adhesive off the window and for removing stubborn stains from my rims.
To UPDATE: Shoe Scuffs on Rocker Pannel Door Jam Plastic Results.
Quick Reply: UPDATE: Shoe Scuffs on Rocker Pannel Door Jam Plastic Results.
