Mysterious button ??
As I was working around this area today changing my coolant, I noticed a black push button sort of like the ones for interior lights that are in the door jambs. This was driver side, about 6" in front of the hood latch ??
Was there an optional "under hood light" available? That's all I can think this could be for, but of course I don't have the light. I pushed it a few times but nothing happened so I'm curious, anyone??
NSF
NSF
What year? I have an '06 that has the hood light, but there is no (OEM) switch/button to turn it on or off. Most likely someone installed a switch for some purpose ... what, I don't know.
The '05s came with a light under the hood. IIRC, '06 had the light, and sometime in the '07 MY, the light went away. Whenever this was eliminated (and as I implied, not exactly sure), the hood liner did away with the cutout. I can't say I ever heard anyone mention a switch location, though. I do remember that you could wire and put in a light in the later years, which leads me to believe the shut-off switch must have been retained.
I just went and looked on my '05, and I found what looks like a switch on the edge of the coolant surge tank (almost as if it is also used to secure one edge of the tank. It has a rubber cover, but mine doesn't depress, and I can't see anything that would depress it when closed anyway. My under hood light burned out years ago, and it never worked very well, so I never replaced the bulb.
Do you have a pic of the "switch", or does my description match the placing?
I'll take a photo tomorrow, maybe someone will know what it is
I'm stumped
NSF
Received 1,597 Likes
Could it be an aftermarket alarm switch ?
Race Car Tech
My 06 has an under hood light, and it has a mercury switch to turn on-off when the hood is opened or closed.
Here is a pic of my engine bay, and I see no switch. The "switch" looking thingy by the overflow tank is a rubber cap to cover for the bolt threads for the bolt that holds the tank in place.
Well, that explains why mine does not depress.
The description does say switch (which makes sense, because even when mine had a working bulb, it turned off). Where, pray tell, is it on the car?
Now, I'm just curious. I may even replace the bulb for giggles.
Race Car Tech
The lamp mercury tilt switch is inside the hood lamp housing. The switch is a tiny glass bulb with mercury inside the bulb. When it tilts up, the mercury falls and makes the electrical connection across the contacts. When you close the hood, the mercury falls away from the contact points, and the lamp shuts off.
owc6 (03-02-2016)
4SUMERZ (03-02-2016)
Yep that's it, Paul to the rescue AGAIN . I guess I could have thought of pulling it up to see what it was huh?
I find it hard to believe GM thought of protecting prying fingers from being cut and yet faulty H.B. are still in existence, of course the cost is greatly increased on that one malady. Mine is wobbling away as usual but no chirping yet
Thanks again Paul
NSF
Thanks again Paul
NSF
Race Car Tech
Thanks again Paul
NSF
Thanks again Paul
NSF
I had my overflow tank off when I ran some wires behind it for my front parking camera. That is the one and only reason that I knew what it was.
