is this engine noise normal?
Old 01-13-2012, 06:10 PM
MR_JLR
MR_JLR's Avatar
Default is this engine noise normal?
Sounds like loose change on drivers side. Can really only be heard by putting head(or camera) around brake fluid area. Never noticed the noise until I had a tapping sound a few weeks ago coming home from the gym(went away after I turned off then restarted the engine). No power loss, no oil loss, just this weird metallic whirring sound on the driver side. Not the alternator.
any feedback is greatly appreciated. Recorded with iphone so you may have to adjust your volume.
Old 01-13-2012, 06:35 PM
JLB768
JLB768's Avatar
My hearing is shot from years of installing audio equipment, but I don't hear anything that sounds different from my two previous C6's, or my current.
Old 01-13-2012, 07:10 PM
GS-Zero
GS-Zero's Avatar
Probably the air conditioning compressor. It has a tendency to rattle against the frame, so I'm told.
Old 01-13-2012, 08:54 PM
MR_JLR
MR_JLR's Avatar
Ok thanks for the responses
Old 01-13-2012, 09:00 PM
oilrigpilot
Cruising
oilrigpilot's Avatar
Sounds like mine... although i have an SC installed... but, i didn't hear anything that would concern me... I too have a slight valve tap...normal i think
Old 01-13-2012, 09:33 PM
KKJ
KKJ's Avatar
Sounds like mine too. Mine seems the loudest in the same area as yours, but I have a case of OCD with any little noise from my car
Old 01-13-2012, 09:59 PM
MR_JLR
MR_JLR's Avatar
Yeah tell me about it. Never would of noticed it had I not had a "tap, tap, ,tap sound that went away went I turned the car off and restarted it. Came out of nowhere. No I focus on that one area lol. Car drives fine but i feel like something up with this "loose change rattle/whirring sound" even thought it could have very well been there before.
Old 01-13-2012, 10:09 PM
KenHorse
KenHorse's Avatar
Location: I live my life by 2 rules. 1) Never share everything you know. 2)
Received 2,400 Likes on 1,365 Posts
St. Jude Donor '11-'12-'13, '16-'17-'18
All I hear is exhaust and injector noise
Old 01-13-2012, 10:12 PM
JRHAWK9
JRHAWK9's Avatar
that's what I seem to hear too...although can't tell for sure from the video, but it sure sounds like injector noise to me.
Old 01-13-2012, 10:16 PM
MR_JLR
MR_JLR's Avatar
turn your volume up if possible, the rattle starts 10 seconds into the video. it's not super loud as i have to put my head by the brake fluid to hear it but i just wanted to see what others thought.
Old 01-13-2012, 10:29 PM
SilverScorp
SilverScorp's Avatar
Purring like a kitten to me . Sounds like a LSx. You certainly don't have harmonic balancer issues.
Old 01-14-2012, 09:50 AM
Larry/car
Larry/car's Avatar
You don't have the engine cover on. The cover could silence or lower the noise.
Old 01-14-2012, 10:02 AM
MR_JLR
MR_JLR's Avatar
I took the cover off to see if I could pinpoint the noise better. Sounds like its somewhere in-between the valve cover and header. Here's one with the cover on, sounds like a whistling noise as i move the phone in and out(turn volume up, recorded with phone)
I've listened to another 2008 in person and didn't hear it so I got concerned of course
Old 01-14-2012, 01:46 PM
JCtx
JCtx's Avatar
It's actually pretty darn quiet man; consider yourself lucky. It could be a very small exhaust leak if at all, but nothing of concern. Just drive it, and unless it gets worse over time, when it's obvious something is wrong, don't even bother taking it to a dealer. Mine was 10 times louder than yours, and was told it was normal . Take care.
Old 01-14-2012, 02:29 PM
MR_JLR
MR_JLR's Avatar
ok, thanks for the response
Old 01-14-2012, 03:14 PM
king off the hill
king off the hill's Avatar
Default look under
I no get under the car. now were your starter motor is.check were the exaust goes by close to the starter. theres a plastic cover is it on correct or twisted.
Old 01-14-2012, 03:22 PM
rayk
rayk's Avatar
That's my take.
To is this engine noise normal?
Old 01-14-2012, 04:05 PM
Jimmy W1
Jimmy W1's Avatar
I was hearing a clicking noise in my 05 that would last until the engine warmed up. I think it is the AC clicking on and off. But I think that is on the passenger side.
Old 01-14-2012, 04:42 PM
HKILP7M8
HKILP7M8's Avatar
Sounds normal to me, sounds like mine, mine may be a bit louder...
Old 01-14-2012, 05:01 PM
brettbolt
Support Corvetteforum!
brettbolt's Avatar
If you get a large flexible hose (say 2 -3 inches diameter), you can put one end of it up to your ear and use the other end to probe around the engine.
I've used that method to locate vacuum leaks and other engine problems.
Hope its nothing serious.
Quick Reply: is this engine noise normal?
