Code P2A04 Check Engine
Old 07-09-2022, 07:25 PM
starvnmarvin1
starvnmarvin1's Avatar
Default Code P2A04 Check Engine
Have 2007 base convertible check engine light came on reading code P2A04. Looks like 02 Sensor. Can someone recommend a "brand" and possibly cost of sensor. Is there more than 1 sensor. Sorry but never replaced one before. Car has Z51 package Pace Car with 53K
Thanks in advance
Old 07-09-2022, 08:27 PM
New Vette Man
New Vette Man's Avatar
Hope this helps you out. Go to Rock Auto for more info on types available, try to stay with OEM or AC Delco. Your read out might tell you which sensor is bad. An OBD Scan Tool will usually identify Oxygen Sensors by the Bank Number (B1 = Bank 1) and Sensor Number (S1 = Sensor 1). Bank 1 will always contain Cylinder 1, which is located closest to the front of the engine.
Old 07-09-2022, 08:44 PM
C6ToGo
C6ToGo's Avatar
Received 1,116 Likes on 693 Posts
As shown, you have four O2 sensors. P2A04 refers to Bank 2, Sensor 2. That is the passenger side downstream sensor.
Recommend getting OEM or good name brand. Don't get a universal one.
Old 07-10-2022, 07:08 AM
starvnmarvin1
Thanks for the pictures and great reply. It surely helps. When I pulled the codes along with P2A04 came the following message
H02S Performance Bank2 Sensor 2
DTC Severity 2of 3 Repair Immediatley if drivablity issue.
I recently had the Torque Tube replace did this have anything to do with 02 Sensor possibly
Thanks in advance
Old 07-10-2022, 08:49 AM
BadAV
BadAV's Avatar
Received 2,677 Likes on 1,701 Posts
Thanks in advance
It's certainly a possibility. Get under the car and check the rear passenger side sensor to make sure they got the connector fully seated, and to see if they possibly damaged some wiring. Or take the car back to the shop that did the torque tube and ask them to check things out.
Old 07-10-2022, 11:38 AM
farmington
farmington's Avatar
Received 1,119 Likes on 798 Posts
The downstream O2 sensors just check the condition of the cats. Nothing for engine operation.
Old 07-10-2022, 12:31 PM
starvnmarvin1
I will take care of the torque tube issue tomarrow. Have the shop check it out. Great information and thanks for the help much appreciated. Will advise as soon as I get an answer. As for OEM sensors looks like my choice is Delphi or AC Delco. Any time I have anything done as repairs everthing ever replaced ia 100% original. Having as # Pace Car I want it stock
To Code P2A04 Check Engine
Quick Reply: Code P2A04 Check Engine
