Old 03-03-2015, 12:39 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Engine and Powertrain
Print Wikipost
Stuck in park, 2005 C6
Old 11-13-2017, 01:16 PM
  #81
719c6
719c6's Avatar
I have already picked up some switches... just in case.
Old 11-13-2017, 02:25 PM
  #82
CSixDude
CSixDude's Avatar
The root cause and fix posted here 6 months ago. Replace the microswitch.
https://www.corvetteforum.com/forums...use-found.html
Old 11-17-2017, 04:57 PM
  #83
MarcL
Cruising
MarcL's Avatar
Did you get the Radio Shack part noted above? or did you find the original with the wires instead of terminals?
I ordered some of the Radio Shack ones posted in here (without the roller), but I'd prefer to find the pre-wired variant.
I have used up my google search quota for the month researching this part. In the 13 years since my C6 was built, I'm guessing that that part company has been bought and sold a few times. I have found similar looking switches from Burgess, SAIA, Johnson Controls, and Honeywell.
Old 11-18-2017, 05:26 PM
  #84
EngineerBill
EngineerBill's Avatar
Default How to get out of park anytime
I finally checked my 05 to see if putting the car in accessory mode first and shifting to neutral then stopping and starting the car works.
IT DOES!!!!!
Anytime you can't get it to shift out of park, just shut off the car and do this and you will be on your way.
Old 08-24-2019, 09:22 PM
  #85
CPTLeDonne
Cruising
CPTLeDonne's Avatar
Default Video that shows everything right here.
Here's a decent video that shows how to fix the issue. Might be a slight pain in the *** to do it, but better than paying a stealership hundreds of your hard-earned $$$. I personally would not cut off the piece like he did. I would drill a hole in it and wire it back and out of the way. This was VERY helpful.
Old 08-25-2019, 11:24 AM
  #86
dcarter0001
dcarter0001's Avatar
On my 2005, sometimes it will not move out of park and sometimes it will. It seems like when the car is hot it will not move out of park. Sometimes when i work with it, it finally works. Does this mean the micro switch is starting to fail or do I have an another problem?
Old 09-20-2021, 06:58 PM
  #87
Waves
Waves's Avatar
I wasn't able to take it out of park at all anymore. Not even in accessory mode. I had two replacement micro-switches on hand and was ready to replace them but after getting the micro-switch out of the two clips that keep it down, I noticed that I can open it easily, so I popped it open and cleaned both contacts (fixed and mobile) with fine sandpaper and after that I sprayed some contacts cleaner. Works like new now!
Quick Reply: Stuck in park, 2005 C6
