I just remembered why I don't change my own oil anymore...
Really need to invest in some quality tools ....
I use Craftsman, never had an issuue ....
Last "stress test", was my inability to remove a caliper bolt on a Dodge,
wound up placing the wrench handel on top of a jack stand and slowly lowered the car causing the wrench handle to rotate. The weight of the car did the trick, nothing cracked/broke... May'be a red neck fix, but it worked.
Received 3,089 Likes
2021 C6 of the Year Finalist - Modified
Sure you were turning the drain plug the right way?
☠☣☢ Semper Ebrius ☢☣☠
...Last "stress test", was my inability to remove a caliper bolt on a Dodge, wound up placing the wrench handel on top of a jack stand and slowly lowered the car causing the wrench handle to rotate. The weight of the car did the trick, nothing cracked/broke... May'be a red neck fix, but it worked.
I always spill oil all over the place. I am almost at the point where just remove the drain plug and let it flow unto the floor. I always have to clean up anyway.
