Cherry Bomb Mufflers??
Did a search to see if anyone is using these and came up with an old thread from 2008, so I decided to start a new one. They have this new exreme mufflers and I bet that they would sound really good on the Z06.
http://www.cherrybomb.com/Catalog/ex...reme-7427.aspx
They also now seem to have an exhaust system for the C6 using the same muffler.
http://www.cherrybomb.com/Catalog/Se...ar.aspx?id=854
Maybe they will make it for a 3 inch axle back......
Does anyone here have this exhaust or mufflers on their vette and if so do you like it?? Back in the day if you wanted deep and loud they were the mufflers to get!!
They also have these and I bet that they would make a Great bullet exhaust system.....
http://www.cherrybomb.com/Catalog/gl...ack-87524.aspx
Mark
Mark
Perfect fit...Go for it
There's absolutely nothing wrong with having a muffler shop custom fabricate an exhaust system for you. You simply select your muffler(s) and exhaust tips, then have muffler shop bend all of the piping & weld it together. I had one built for my '98 Firebird Formula and it sounded great. I also selected the Magnaflow mufflers and exhaust tips for my 2000 BMW 540i, which also sounded fantastic. It's really no different from what companies like Magnaflow and Borla do, except that you can select the exact components that you want. It's also a fraction of the cost. If you don't like the sound of it, the muffler shop can simply swap out the mufflers & reweld it. It's no big deal really. The key is finding a muffler shop that has someone that is knowledgeable and can help you select the right muffler to fit your taste.
