Christmas Weekend Pioneer X930bt Double Din Special!
Former Vendor
MUCH TO MY SURPRISE!
I had delivered to me on Friday afternoon
13 cases of Pioneer X930bt radios!
I have not been able to get these for weeks
SO
This Christmas weekend only!
Saturday, Sunday and The Day after Monday!
$799.99
for the X930BT package!
You will get
1- Pioneer x930bt radio
1- GM antenna adapter
1- Pac (05-10) or Metra (11-12) Harness
1- Set of install brackets
1- Metra 95-3304 dash kit
These are going to go fast!
I have had many of you ask me for this radio over the last couple weeks. I will be going back and looking for all messages I can find to contact all of you as well. If I miss someone its not intentional!
CLICK HERE TO ORDER YOURS!
call me with questions
Monday- 608 568 3011
I will be answering emails
and PM's all weekend
Pioneerx930bt installed
Naples FL
Can you provide detailed installation instrUctions?
Former Vendor
With our prewire its a simple as plug and play if you have no SW controls
Here is what your looking at
Remove center console lid(4 screws)
remove tombstone on bezel or inside console there is two screws to remove
pull up bparking brake handle
behind boot there is 2 more screws
remove these
bezel will then lift up with only thing remaining is a couple clips it snaps into and a few connectors to deal with pending what you have for options ie hazzard, heated seats ect
bezel is off
remove the screws holding radio
unplug factory harness from factory radio
our prewired harness will need one wire connected if you have no SW controls
the extended wire from the orange white on radio harness
will connect to the gray with black strip on active handling button
route BT mic to desired location
route GPS antenna ( we normally put under center channel speaker cover)
plug in the new harness to the stock harness
check for power
reinstall radio
and back track the original steps above.
If you have SW controls
you will need to connect the SW control module to the car harness. Pending what year of car( metra or pac harness)and model of SW controls we go with there is a couple connecitons needed
Other than this thats all there really is to it.
I have instructions for bezel removal on my laptop at home. I didnt realize I didnt have them here
I am always a phone call or email away for help as well.
Call me if you have any more questions
Dennis
Here is a pic of our prewired 930 and 130 units ready to be plugged in
